[postgis-users] Buffering with JDBC
Leticia lgomez at itba.edu.ar
Fri May 11 10:27:59 PDT 2007
Now I am using this version http://www.vividsolutions.com/jump/
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of backo
Sent: Friday, May 11, 2007 2:23 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Buffering with JDBC
Thank you for your answer!!
I would like to ask you where can I find this vivdsolutions libraries?
Also, I would like to ask if someone knows what is the reason for exception,
I coppied the code from the PostGIS maual but it does not work although it
should have!!
Der WEB.DE SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070511/078df6fa/attachment.html>
