[postgis-users] Problem with Contains in Postgis 1.2.1
Michael Fuhr mike at fuhr.org
Tue May 15 03:45:34 PDT 2007
Regarding the Contains() problem discussed in:
http://postgis.refractions.net/pipermail/postgis-users/2007-April/015317.html
I get true (as expected) for the test case in 1.2.2SVN.  However,
the second of the following examples appears to be wrong.  The only
difference between the polygons in each example is in the third and
fourth points.  Relate() returns the same relationship in all three
examples but Contains() incorrectly reports false in Example 2,
where X in the third and fourth points of the polygon matches X in
the point.
Example 1:
select Relate(GeomFromText('POLYGON((0 0,0 20,9 20,9 30,30 30,30 0,0 0))'),
              GeomFromText('POINT(10 10)'));
  relate
 0F2FF1FF2
(1 row)
select Contains(GeomFromText('POLYGON((0 0,0 20,9 20,9 30,30 30,30 0,0 0))'),
 contains
 t
(1 row)
Example 2:
select Relate(GeomFromText('POLYGON((0 0,0 20,10 20,10 30,30 30,30 0,0 0))'),
  relate
 0F2FF1FF2
(1 row)
select Contains(GeomFromText('POLYGON((0 0,0 20,10 20,10 30,30 30,30 0,0 0))'),
 contains
 f
(1 row)
Example 3:
select Relate(GeomFromText('POLYGON((0 0,0 20,11 20,11 30,30 30,30 0,0 0))'),
  relate
 0F2FF1FF2
(1 row)
select Contains(GeomFromText('POLYGON((0 0,0 20,11 20,11 30,30 30,30 0,0 0))'),
 contains
 t
(1 row)
Michael Fuhr
