[postgis-users] Postgis 2.0 wishlist
Paul Ramsey pramsey at refractions.net
Tue May 15 07:17:20 PDT 2007
On 15-May-07, at 4:33 AM, Willy-Bas Loos wrote:
> If you're changing alle the function names, maybe it's time to make
> system objects of them, stored in a seperate system schema (along
> with the types, operators, etc)?
This is doable now, the main problem for newbies seems to be setting
the search_path every single time so they have access to them.
> Other than that it would be nice to add descriptions to the
> functions and operators in SQL, e.g. to indicate what the input for
> each function should be when the number of arguments varies for
> functions with equal names.
How does one recover those descriptions at the commandline? Does \d
functionname work?
P
