[postgis-users] Scale without translate?
Jeff Dege jdege at korterra.com
Thu May 17 15:13:10 PDT 2007
In my case, these are one-time translations, done during development,
before install.  Whether they take ten seconds or two minutes makes very
little difference.
If I did have users waiting on this function, though, I'd seriously
consider writing a stored procedure that called centroid once, and used
the results and the scaling factor to calculate the appropriate
arguments so that I could have one call to affine(), instead of two
calls to translate and one to scale.
(Can we do an aside to an aside to an aside?
Is the optimizer smart enough to compose multiple translations and
scalings and rotations?  So that when we do a nested
translate(scale(translate))), we only modify the geometry once, instead
of creating the intermediate geometries?
If so, the optimization I described above would gain little.)
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Bruce Rindahl
> Sent: Thursday, May 17, 2007 5:03 PM
> To: 'PostGIS Users Discussion'
> Subject: RE: [postgis-users] Scale without translate?
> Don't know.  How many times will you do this or how large is
> the table?  If
> it will be an issue then you may want to play with this a bit
> by loading the
> centroid coordinates into a scratch table and the calling the
> function below
> with those values.
> Bruce
> Behalf Of Rob Agar
> Sent: Thursday, May 17, 2007 4:00 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Scale without translate?
> Bruce Rindahl wrote:
> > SELECT translate(
> > scale(
> > translate(the_geom,-x(centroid(the_geom)),-y(centroid(the_geom)))
> > ,myScale)
> > ,x(centroid(the_geom)),y(centroid(the_geom)))
> on a side point, is the postgresql optimizer smart enough not to call
> centroid() four times in this case?
> Rob
> postgis-users mailing list
