[postgis-users] How to load Invalid Geometries PostGIS
Nicolas Ribot nicky666 at gmail.com
Sun May 20 09:22:11 PDT 2007
On 5/18/07, Orlando Giovanny Solarte Delgado <orsolarte at gmail.com> wrote:
> Hi list.
> I am developing geodatabase with PostGIS 1.2. I am tryin load shapefile
> using shp2psql method from postgis. However, when I load shapefile
> using sql. It say: "NOTICE:  Ring Self-intersection", "violates check
> constraint "geometry_valid_check".
> Before to load shapefile, I test using chek_geomatry tool from ArcTools from
> ArcGIS 9.2, it say: "Valid geometries", but postgis say  "violates check
> So. How I can repair may shapefile before load postgis??. There is some tool
> different Check and repair Geometrias from ArcGIS?
> Thanks.
try using Jump (http://www.vividsolutions.com/jump/) or OpenJump
(http://openjump.org/) to load the shapefile and check it.
You will be able to visualize invalid geometries and repair them
Nicolas
