[postgis-users] error in extent command
temiz temiz at deprem.gov.tr
Mon May 21 13:16:54 PDT 2007
I created spatial db as:
bzk2=# select addgeometrycolumn('exp1','geom',32767,'GEOMETRY',2);
then I wanted to insert  this value to spatial db. But I received this
message:
update exp1 set geom=(select extent(wkb_geometry) from shey6  where
shey6.cat=2);
ERROR:  new row for relation "exp1" violates check constraint
"enforce_srid_geom"
what can I do ?
regards
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
