[postgis-users] multipolygon polygon test intersects
Christo Du Preez christo at mecola.com
Mon May 28 06:54:17 PDT 2007
Thanx Nicolas,
What if I store my polygons in a geometrycollection instead of a
multipolygon and then use the && operator?
Nicolas Ribot wrote:
>> Hi all,
>> How would I test if a given polygon intersects with one of the polygons
>> currently in a multypolygon geometry?
>> I tried the && operator but if I'm not mistaken it will test the given
>> polygon against the bounding box of the whole multipolygon geometry and
>> not each one individually.
>> Thanx in advance.
> Hi,
> I think you will have to explode your multipolyons into single
> polygons to do that.
> A multipolygon is considered by postgis as a single object, thus &&
> and overlaps (or other operators) will work on all polygons composing
> the multi.
> You can use dump() to generate polygons out of multipolygon, then test
> each individual polygon.
> HTH
> Nicolas
> postgis-users mailing list
Christo Du Preez
Senior Software Engineer
Mecola IT
Mobile:	 +27 [0]83 326 8087
Skype:	 christodupreez
Website: http://www.locateandtrade.co.za
