[postgis-users] Modify encoding of shapefile
Arnaud Lesauvage arnaud.lesauvage at supermail.fr
Tue May 29 13:11:00 PDT 2007
Nicolas Ribot a écrit :
>> I am not sure this is the same problem.
>> It looks like your file is in codepage 1252 but your client encoding is set to UNICODE.
>> Doesn't "SET client_encoding TO WIN1252;" help in your case ?
> Yes, you may be right.
> I'm not on windows, though, but on Linux.
> The sql script I use worked well on Mac, with the same shapefile.
Strange.
On what OS was the shapefile created ?
