[postgis-users] Shortest Distance from Every Point
Matthew Pulis mpulis at gmail.com
Mon Nov 5 08:06:39 PST 2007
Thanks for the explanation both Paul and Regina :) thanks :)
On 11/5/07, Paul Ramsey <pramsey at refractions.net> wrote:
> The "maximum minimum distance" has nothing to do with PostGIS, it's
> just an idea: is there a distance you expect all your minimum
> distances to be smaller than?  If so, you can winnow out pairings of
> cities that will *not* yield a minimum distance.  This is what the
> ST_Expand does, it turns a point into a box, with a distance of ?mmd?
> from each side to the center.  And the && tests containment in that
> box, using the spatial index operator.
> P
> On 4-Nov-07, at 4:21 PM, Matthew Pulis wrote:
> > Can you please explain further why u used the EXPAND? Didn't much
> > get what is its use? And is mmd a thing which has to do with PostGis ?
> > On 11/4/07, Paul Ramsey <pramsey at refractions.net> wrote:
> > Well, you have to build the cartesian product of every city
> > combination and then measure every distance in that virtual table, so
> > it's not going to scale well at all as the input table gets bigger.
> > However, if you know the "maximum minimum distance" (?mmd?) you can
> > add a spatial constraint that should at least keep the calculations
> > in the O(n*log(n)) range... (you'll need a spatial index on the table
> > for best effect as the table gets larger)
> > SELECT DISTINCT ON (c1)
> >      c1.city_name AS "c1",
> >      c2.city_name AS "c2",
> >      distance(c1.the_geom, c2.the_geom),
> >      makeline(c1.the_geom, c2.the_geom)
> > FROM
> >      city c1
> > JOIN
> >      city c2
> >      ON (
> >          c1.city_name <> c2.city_name AND
> >          c1.the_geom && ST_Expand(c2.the_geom, ?mmd?)
> > ORDER BY c1, distance ASC
> > Paul
> > PS - Nice query, BTW.
> > On 4-Nov-07, at 9:15 AM, Yancho wrote:
> > > Just wanted to say that I managed to write this Query :
> > >     distance( c1.the_geom, c2.the_geom),
> > > FROM
> > >     city c1
> > > JOIN
> > >     city c2
> > >     ON (
> > > It works perfectly, however how much do you think it can scale ? On
> > > 16 rows
> > > it didnt take long, however or 28,000 rows? Will it use the O(n^2)
> > > scalability?
> > > Thanks
> > > Yancho wrote:
> > >> Hi,
> > >> I am trying to make a query so it parses through all the 16 cities
> > >> i have
> > >> in
> > >> a table called city, and for each city, picks the nearest city,
> > >> and gives
> > >> me
> > >> the distance between both cities.
> > >> This is the query I made :
> > >> select
> > >> c.city_name, astext(c.the_geom), distance(c.the_geom,
> > d.the_geom) AS
> > >> Distance, d.city_name, astext(d.the_geom)
> > >> from city c, city d
> > >> where
> > >> c.city_name = (
> > >> select c.city_name order by c.city_name ASC
> > >> and
> > >> d.city_name = (
> > >> select d.city_name order by d.city_name DESC
> > >> group by c.city_name
> > >> order by Distance DESC
> > >> LIMIT 1;
> > >> But I am getting this error : ERROR: column "c.the_geom" must
> > >> appear in
> > >> the
> > >> GROUP BY clause or be used in an aggregate function
> > >> I am seeing no reason why I should add c.the_geom, anyone can
> > >> enlighten me
> > >> more on why I should group by the_geom and after all if it does
> > make
> > >> sense?
> > >> Thanks
> > >> Matthew Pulis
> > >> www.solutions-lab.net // www.mepa-clan.info
> > >> _______________________________________________
> > >> postgis-users mailing list
> > >> postgis-users at postgis.refractions.net
> > >> http://postgis.refractions.net/mailman/listinfo/postgis-users
> > > View this message in context: http://www.nabble.com/Shortest-
> > > Distance-from-Every-Point-tf4743229.html#a13575499
> > > Sent from the PostGIS - User mailing list archive at Nabble.com.
> > Matthew Pulis
Matthew Pulis
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071105/5cfbdbd7/attachment.html>
