[postgis-users] GEOS union() error
Lee Keel
lee.keel at uai.com
Tue Nov 6 14:29:57 PST 2007
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Martin Davis
> Sent: Tuesday, November 06, 2007 1:02 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] GEOS union() error
> You could try doing the union and then the buffer - that should be more
> robust. Something like:
> select buffer(geomunion(the_geom), 400) as the_geom from main
> (although I may not have quite the right syntax)
[Lee Keel]
Well that got me past that error, but now I have a much bigger problem. I
need a way to speed up the geomunion process. I know I am asking a lot of
this function, but I have about 40K rows and the process to do the geomunion
has been running over 80 mins and still going. Does anyone have a better
idea on how I can get the same results?
Please see attached email for original description....
Thanks in advance,
Lee
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
An embedded message was scrubbed...
Subject: [postgis-users] GEOS union() error
Date: Tue, 6 Nov 2007 12:41:44 -0600
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071106/bf217cfa/attachment.mht>
