[postgis-users] GEOS union() error
Obe, Regina robe.dnd at cityofboston.gov
Wed Nov 7 07:58:03 PST 2007
have you tried increasing your shared_buffers and temp_buffers setting?
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Lee
Keel
Sent: Wednesday, November 07, 2007 10:45 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] GEOS union() error
> bounces at postgis.refractions.net] On Behalf Of Obe, Regina
> Sent: Wednesday, November 07, 2007 9:01 AM
> Well I've never seen that particular error before.  Usually if I need
to
> bump up memsize, it explicitly says its "OUT OF MEMORY"
> The specific error sounds like its trying to write to a non-existent
> address space or space already in use.  Not quite sure what would
cause
> that.
> Does it work if you limit your buffering to something like below?
> SELECT buffer(collect(the_geom), 400) as the_geom
> FROM (SELECT the_geom from main limit 10) As newmain
> Hope that helps,
> Regina
[Lee Keel]
Well this was an interesting test...  I tried 10 and it work.  I tried
100
and it worked.  Well I kept trying different things and it appears that
everything works up to limit of 444.  At 445, I get the "St9bad_alloc"
error.  I have confirmed that collect works with limits, but if I don't
add
limit I get the following error:
ERROR: out of memory
SQL state: 53200
Detail: Failed on request of size 520184.
I have changed my work_mem to 1200MB and still got the error.
I have also done a count on the number of points and there are 1,244
points
for the first 444 geoms, and 1,246 for 445. (FYI, total number of points
for
table is 104772.)  So there is no logical reason for number of points to
be
causing the problem either.  Another test that I performed was to move
the
collect outside of the buffer like:
select buffer(the_geom, 400) from (select collect(the_geom) as the_geom
from
(select the_geom from main limit 445)foo2) foo
This resulted in the same "St9bad_alloc" error.  However, using 444 as
limit
worked.
-LK
This email and any files transmitted with it are confidential and
intended solely for the use of the individual or entity to whom they are
addressed. If you have received this email in error please notify the
sender. This message contains confidential information and is intended
only for the individual named. If you are not the named addressee you
should not disseminate, distribute or copy this e-mail.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
