[postgis-users] geomunion revisited....
Lee Keel lee.keel at uai.com
Tue Nov 13 08:33:28 PST 2007
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Kevin Neufeld
> Sent: Tuesday, November 13, 2007 12:40 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] geomunion revisited....
> Also, I think you may be after the SQL syntax UNION ALL, not UNION, if
> you are simply after concatenating the resultset from table 2 to table 1.
> select simplify(...
> UNION ALL
> select simplify(...
> Also, I too would be curious how buffer(collect(...), 0) fares for you
> instead of geomunion() for your final 5 hour query.
> Since you're doing this all at once anyway, it may work.  Geomunion() is
> an aggregate for the two geometry method.  Which means that it will
> slowly add one geometry at a time to an every growing resulting
> geometry.  Buffer(collect(...), 0) will decontruct the collection once,
> and rebuild it once to a union-ed geometry.
> -- Kevin
> Josh Livni wrote:
> > I think running buffer(bunch_of_geoms,0) rather than
> > geomunion(bunch_of_geoms) might be faster.
> > That said, still seems it takes a bit long.  If it were me I'd try
> > playing around by first creating a table with your results, eg:
> > '''create table simple_buffers as (
> > select simplify(buffer(simplify(the_geom, 5), 400), 150) as the_geom
> > from table1
> > union
> > from table2); '''
> > then you could create a GiST index on the_geom of your new table, run
> > vacuum analyze on it, and then try the geomunion and buffer to test.
> > With 32k+ rows, depending on how much they overlap, that might help a
> > little, or at least help potentially isolate the issue if it does take
> > as long.
> > Also I assume you've modified your postgres config away from the
> > defaults to take advantage of more memory on your machine, etc.
> >  -Josh
[Lee Keel]
Well, I have played with this some more and here is what I have found.
I tried using the buffer(collect(the_geom), 0) on the largest table (about
30K rows) and I get the following error:
NOTICE:  St9bad_alloc
ERROR: GEOS buffer() threw an error!
SQL state: XX000
This entire table is only 5872KB but when I monitor this buffer process the
memory gets over 1.7GB before it finally crashes out.  Even if you were to
triple the memory I can't see where it would ever get to 1.7GB.  NOTE: When
monitoring the process of doing just the collect(the_geom) the memory
footprint gets up to about 26-28MB and takes about 2.5 minutes.  This leads
me to think there might be a memory leak in the buffer().
I tried using a test table.  This new table is 3704KB.  But I realized that
a gist index is not going to buy me anything because it is still going to
pull the entire table.
I have listed my config settings below.  I am not sure how much more I can
tweak them since I am running on 64bit Vista.  I have had a few posts in the
last week that have basically said that the windows version of this can't be
tweaked much more due to constraints by windows.
shared_buffers = 256MB
temp_buffers = 32MB
max_prepared_transactions = 100
work_mem = 16MB
maintenance_work_mem = 256MB
max_stack_depth = 3MB
Thanks for everyone's help and attention to this.
Lee
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
