[postgis-users] Problem with mismatched coordinate systems
Russell Horn albanach at gmail.com
Wed Nov 21 08:21:23 PST 2007
I am very new to PostGIS, please bear with me. I've had a lot of help
from #postgis on IRC but I continue to have trouble and hope someone
here can assist.
I have two data sets from the UK Ordnance Survey which when imported
to PostGIS and plotted are not matching up:
http://exiled.albanach.com/chester.png
One data set contains shape files (no .prj file) which give me an
outline of part of the UK.
The data set is available here:
http://www.ordnancesurvey.co.uk/products/boundaryline/sampledata/Layered_Shape.zip
The documentation states that the coordinate system is National Grid
(NG). I understand this is OSGB1936 / EPSG:27700
The other data set contains a list of place names, together with
Eastings and Northings like this:
CHESTER*CHESHIRE COUNTY*340363*366880
I have then converted that to Long Lat to give me
53.196,-2.894,CHESTER
I can paste my Long Lat values into Google maps and get the right
place, so that conversion seems to have worked.
To import my shape files I did this:
shp2pgsql -s 27700 county_region.shp public.ch_county > /tmp/county.sql
To import my place names, I did this:
ogr2ogr -f "ESRI Shapefile"  gaz/ chester.csv
Where chester.csv looks like this
lat,long,value
I then did
ogr2ogr -f "ESRI Shapefile" gaz/ os.vrt
To make my shapefiles where os.vrt looks like this:
<OGRVRTDataSource>
  <OGRVRTLayer name="OS_Gazetteer">
    <SrcDataSource relativeToVRT="1">gaz</SrcDataSource>
    <SrcLayer>chester</SrcLayer>
    <GeometryType>wkbPoint</GeometryType>
    <LayerSRS>EPSG:27700</LayerSRS>
    <GeometryField encoding="PointFromColumns" x="long" y="lat"/>
  </OGRVRTLayer>
</OGRVRTDataSource>
Changing LayerSRS value didn't seem to change anything.
I converted to sql like this:
shp2pgsql OS_Gazetteer.shp public.chesgaz > gaz.sql
I then imported my two SQL files into Postgres.
When  plot my data using qgis I end up with Chester being plotted way
off my map like the image I pointed to earlier:
I know I'm doing something wrong here, but I'm at a bit of a loss as
to what it is, and where to go from here.
Any help would be very much appreciated.
Thanks,
Russell
