[postgis-users] CentOS 4.5 postgis-1.1.0.spec patch
Rob Nagler nagler at bivio.biz
Fri Nov 23 09:45:35 PST 2007
Devrim GÜNDÜZ writes:
> Thanks for that. However, I won't "remove" those patches, but just will
> set the relevant macros to 0, so that we won't build the java related
> packages for RHEL 4.X.
The Geos patch does not work with the stock RHEL 4.5, and the build
fails.  I think %patch1 is missing a -N arg.  Not sure if you can just
append it.
> Thanks again for your contribution.
Gladly.  Thanks for maintaining the rpms.
Cheers,
Rob
