[postgis-users] Problem using GeomFromEWKT with a long LINESTRING
Robert Coup robert.coup at onetrackmind.co.nz
Thu Nov 29 17:19:58 PST 2007
On 30/11/2007, Randy George <rkgeorge at cadmaps.com> wrote:
>     I am having a problem loading a long LINESTRING into a table:
> The following command will create the new record but does not add the_geom
> field. There is no error message. If I shorten the LINESTRING all works as
> expected? I've tried it on a couple of PostGIS systems with the same
> results.
Are you _sure_ its not working?  If you're using PgAdmin or some other GUIs,
they don't display long text values properly (they just come up as empty
boxes). Try doing "SELECT numpoints(the_geom) FROM track;"
I can assure you ~1000 points is not a long linestring ;)
Rob :)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071130/aad11fd9/attachment.html>
