[postgis-users] ERROR: ExteriorRing: geom is not a polygon
Obe, Regina robe.dnd at cityofboston.gov
Tue Oct 2 03:54:08 PDT 2007
Andreas,
You can use ST_NumGeometries
If you just want to know the count of records that have more than one polygon in the multipolygon - then do something like - note for below I am also including ST_GeometryType which will tell you if the geometry field is a Multipolygon or geometry collection or multilinestring etc.  If it's a multilinestring then the ST_NumGeometries tells you the number of line strings, if it's a geometry collection - then it could be a mish mash of anything like opther multipolygons etc.  Hopefully you've only got multipolygons or polygons in there.
SELECT count(gid) As totrecords, ST_GeometryType(the_geom) as the_type
FROM sometable
WHERE ST_NumGeometries(the_geom) > 1
GROUP BY ST_GeometryType(the_geom)
If you want to know the actual records
SELECT * , ST_NumGeometries(the_geom) As numPolygons
FROM sometable
Will tell you what multipolygons have more than one polygon in each multipolygon
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Andreas Laggner
Sent: Tuesday, October 02, 2007 6:45 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] ERROR: ExteriorRing: geom is not a polygon
Hi Regina,
how can i be sure to have only one polygon in each multipolygon in a
dataset with thousends of polygons? Exists a function to verify that?
hasta luego      Andreas
Obe, Regina schrieb:
> Yes you do.  ST_ExteriorRing only deals with Polygons not multipolygons or geometry collections.
> There are 2 ways to do it.
> 1) If you have a multipolygon and you are sure you only have one polygon in each multipolygon, then you can do
> SELECT ST_ExteriorRing(ST_GeometryN(the_geom,1))
> FROM ffh_rep
> 2) If you really have multipolygons and you want the exterior ring of each polygon - it's a bit trickier.  Try
> SELECT ST_ExterionRing(ST_GeometryN(the_geom, generate_series(1, ST_NumGeometries(the_geom)))
> FROM ffh_rep
> If you have a set of GeometryCollection hmm that's even trickier.  I would guess 2 layers of series - let me know if that is the case.
> Hope that helps,
> Regina
> Sent: Wednesday, September 26, 2007 7:00 AM
> Subject: [postgis-users] ERROR: ExteriorRing: geom is not a polygon
> Moin users,
> i get an error starting with this query (i want to overlay tables
> according to this
> http://postgis.refractions.net/support/wiki/index.php?ExamplesOverlayTables
> CREATE TEMP TABLE all_lines AS
>    SELECT St_ExteriorRing (the_geom) AS the_geom FROM ffh_rep
>    UNION ALL
>    SELECT St_ExteriorRing (the_geom) AS the_geom FROM spa_rep;
> do i have to force my source data to be polygons? How can i do that?
> cheers      Andreas
>> Not sure I quite understand the question.  You mean to store these 3 geometries separately so you can color code as needed or overlay as needed?
>> In that case you would have 3 separate geometry fields
>>   intersection(ffh_rep.the_geom, spa_rep.the_geom) As geomintersection, ffh_rep.the_geom As ffh_geom, spa_rep.the_geom As spa_geom
>> For the ones where there is only udo or kai then I guess you can fill in the same geometry for all geometry fields.
>> and then overlay them on your map as separate layers as needed
>> or if you mean you just want it to look like figure 1 but not necessarily color coded, then you would do
>> collect(ffh_rep.the_geom, spa_rep.the_geom) as geomcollection
>> Hope that helps,
>> Regina
>> Sent: Thursday, August 30, 2007 7:24 AM
>> Subject: Re: [postgis-users] Union of 7 datasets
>> Moin Regina,
>> the query you suggested is a very big step forward, but it does not
>> exactly what i want to have  ;-)  ...  it seems to me i will need an
>> intersection in one part and not a geomunion!! But i want to ask you:
>> what it does correctly: I now have a union of all geometries from both
>> source datasets.
>> If i have a single udo (ffh_rep) that intersects no kai (spa_rep) the
>> row only has the attributes from udo. Same thing i have with single kai.
>> That is all correct.
>> BUT: If udo and kai intersects i will not have new polygons!! For
>> example: blue is udo (or ffh_rep) and yellow is kai (or spa_rep). I want
>> to have three polygons than with blue only the attributes from udo,
>> yellow only the attributes from kai AND the intersection, polygon number
>> 3, the green one (blue with yellow points) with the attributes from udo
>> and kai (figure1). And now i have one Polygon having the attributes from
>> udo and kai (figure2).
>> figure1:
>> figure1
>> figure2:
>> figure2
>> My query:
>> drop table natura2000;
>> create table natura2000
>>     (ffh_name character varying(80),ffh_land character varying(3),ffh
>> smallint,ffh_id smallint,
>>      spa_name character varying(80),spa_land character varying(3),spa
>> smallint,spa_id smallint)
>>     with oids;
>> select
>> addgeometrycolumn('','natura2000','newgeom','31467','MULTIPOLYGON',2);
>> alter table natura2000 drop constraint enforce_geotype_newgeom;
>> insert into natura2000
>> (ffh_name,ffh_land,ffh,ffh_id,spa_name,spa_land,spa,spa_id,newgeom)
>>  select ffh_rep.ffh_name,ffh_rep.ffh_land,ffh_rep.ffh,ffh_rep.ffh_id,
>>     spa_rep.spa_name,spa_rep.spa_land,spa_rep.spa,spa_rep.spa_id,
>>     geomunion(ffh_rep.the_geom, spa_rep.the_geom) as newgeom
>>   from ffh_rep inner join spa_rep
>>     on (ffh_rep.the_geom && spa_rep.the_geom and
>> intersects(ffh_rep.the_geom, spa_rep.the_geom))
>>     union all
>>  -- the second select gives you ffh_reps that have no spa_reps - your 15
>>       null as spa_name, null as spa_land, null as spa, null as spa_id,
>>       ffh_rep.the_geom as newgeom
>>    from ffh_rep left join spa_rep
>>     where spa_rep.the_geom is null
>>     union all
>>  -- and the 3rd gives you spa_reps that have no ffh_reps. - your 40
>>     select  null as ffh_name, null as ffh_land, null as ffh, null as ffh_id,
>>         spa_rep.the_geom AS newgeom
>>     from spa_rep left join ffh_rep
>>     where ffh_rep.the_geom is null;
>> Cheers    Andreas
>>> Andreas,
>>> You would use the SQL UNION predicate like shown below (actually
>>> slight correction - it is speedier to use UNION ALL especially when
>>> you know there will not be dupiclates since it saves the processing of
>>> sorting to get a distinct UNION does an implicit distinct)  - so I
>>> have corrected below.
>>> -  - I happened to insert comments in between which may have confused
>>> you, but you should be able to run the whole thing as one statement or
>>> if you prefer because of speed issues run each insert separately.
>>> So  would be
>>> INSERT INTO sometable(field1, field2,field3,field4, newgeom)
>>>  SELECT udo.field1, udo.field2, kai.field3, kai.field4,
>>> geomunion(udo.the_geom, kai.the_geom) AS newgeom
>>>   FROM udo INNER JOIN kai ON (udo.the_geom && kai.the_geom AND
>>> intersects(udo.the_geom, kai.the_geom))
>>>   UNION ALL
>>>  -- the second select gives you udos that have no kais - your 15
>>>   SELECT udo.field1, udo.field2, NULL As field3, NULL As field4,
>>> udo.the_geom AS newgeom
>>>   FROM udo LEFT JOIN kai ON (udo.the_geom && kai.the_geom AND
>>>   WHERE kai.the_geom IS NULL
>>>  UNION ALL
>>>  -- and the 3rd gives you kais that have no udos. - your 40
>>>   SELECT NULL As field1, null As field2, kai.field3, kai.field4,
>>> kai.the_geom AS newgeom
>>>   FROM kai LEFT JOIN udo ON (udo.the_geom && kai.the_geom AND
>>>   WHERE udo.the_geom IS NULL;
>>> ----If FULL JOIN were to work (which in theory it should, but doesn't
>>> seem to with Postgis functions  (HINT HINT: would be nice if
>>> that worked and can be easily fixed (but sadly I think the issue is
>>> deeper than Postgis and Geos) - you could write the above much simpler as)
>>> COALESCE(geomunion(udo.the_geom, kai.the_geom), udo.the_geom,
>>>   FROM udo FULL JOIN kai ON (udo.the_geom && kai.the_geom AND
>>> Now if you have a lot of these and the tables are very similar in
>>> nature and named in a predictable way then the way I usually handle it
>>> is to write a pgsql function that dynamically generates the SQL
>>> statement to execute either via a FOR loop and then executes the built
>>> SQL or set of SQL statements or you could do a similar thing in some
>>> scripted language like perl or php.
>>> I take it SQL and pgsql and all that is fairly new to you so it might
>>> be worthwhile (even though its a lot of typing) to do it the long cut
>>> and paste way if nothing more than an exercise to get a feel of how
>>> this all works and visualize the patterns at play.
>>> I don't get the sense that I comprehend your full problem.
>>> Unfortunately I don't have any experience with ArcGIS/ArcView ways of
>>> doing things, so I'm not quite sure if there is an equivalent way in
>>> PostGIS/PostgreSQL  world of doing the same kind of thing and what
>>> exactly that thing is you are doing in ArcGIS.
>>> Union has 3 meanings in PostGIS/PostgreSQL (actually stuff your
>>> favorite spatial/DB here - all non-trivial spatial relational dbs
>>> behave more or less the same)
>>> 1) unioning of record sets (standard ANSI SQL UNION/UNION ALL) - which
>>> is simply a way of stringing together a bunch of selects into a
>>> single result set as shown above
>>> 2)  unioning of 2 geometry fields like shown above with geomunion
>>> 3) Aggregate  geomunion - aggregate variant of the above geomunion
>>> function that groups and unions a whole setof geometries together but
>>> requires you are grouping by some field or set of fields).
>>> I must also mention there is collect (non-aggregate and aggregate
>>> function) which often times is just as effective as the geomunion and
>>> in general much faster processor wise.
>>> Hope that helps,
>>> Regina
>>> Andreas Laggner
>>> Sent: Tuesday, August 28, 2007 9:13 AM
>>>>  Sounds like you would have to go with a full join type thing with
>>> workaround I described below (last example).  So If I understand you
>>> correctly then something like this -
>>>> --the first select gives you those records in both tables your 25 udokai
>>>>  UNION
>>>>  UNION
>>>>  SELECT nul As field1, null As field2, kai.field3, kai.field4,
>>>> Unioned together you should get
>>>> 25 + 15 + 40 = ? 80
>>>> Hope that helps,
>>>> Regina
>>> UFF - that seems to be a complex question, a comprehensive operation and
>>> a lot to type too!!! Thanks a million - i would have spent many time to
>>> find out this query by myself! Ok..... how can i perform your "UNION": I
>>> would just insert my selects one after another in one new table - will
>>> that work well?
>>> I want to aggregate around 20 datasets this way!? Do you know a method
>>> to operate with more datasets (for example 7) in a effektiv manner and
>>> not to do this three selects 6 times?
>>> AND: Am i totally wrong with my aims? It seems to me that is an exotic
>>> think to do with PostGis, but our projects/problems require to aggregate
>>> datasets in almost all cases (around 90%) and that is exactly what one
>>> of the basic functions "Union" in ArcView already carried out ten years
>>> ago. So i would exspect there is a function to perform this operation
>>> easier!? .....i just wonder.....
>>> cheers      Andreas
>>> Andreas Laggner
>>>> Sent: Tuesday, August 28, 2007 7:28 AM
>>>>> BASIC TRICK:  If you want to get all records with no matching
>>> including those that match - put what you would normally put in your
>>> WHERE clause in the JOIN clause and use a LEFT JOIN.
>>>> ok - it seems to me i need some coaching......Yes, I want to get all
>>>> records with no matching including those that match, but i also want to
>>>> dissect the polygons that matches. I will try to explain again just to
>>>> be sure you understood my aims: I have 20 polygons in udo and 50 in kai.
>>>> 10 from kai are intersecting 5 from udo to 25 new polygons i call udokai
>>>> (because they have attributes from udo AND kai). My result should have:
>>>> 15 polygons with attributes only from udo, 40 polygons with attributes
>>>> only from kai AND 25 with attributes from udo and kai! In most cases i
>>>> want to do such a operation because i want to aggregate (spatial
>>>> correct) different datasets!
>>>> Which example from you fits best for this aim? I did not find any
>>>> information on how left join works on the postgis or postgresql
>>> reference...
>>>>> Unfortunately as I have come across before if you need an either or
>>> (if in table 1 or table 2 - ideally you would use a FULL JOIN but for
>>> some reason Postgres chokes when you use postgis functions in the FULL
>>> JOIN clause for the cases I have tried).  In that case you need a
>>> workaround using a set of UNIONS.
>>>>> Simplest case - get all records in g1 one or union of g1 and g2
>>> that intersect
>>>>> NOTE: COALESCE is an ANSI SQL function that will return the first
>>> non-null - when you do a geomunion of a geometry and null you get null
>>> which is why we need COALESCE
>>>>> SELECT g1.field1, g1.field2, COALESCE(geomunion(g1.the_geom,
>>> g2.the_geom), g1.the_geom) AS newgeom
>>>>> FROM g1 LEFT JOIN g2 ON (g1.the_geom && g2.the_geom AND
>>> intersects(g1.the_geom, g2.the_geom))
>>>>> Either of case - get all geometries in g1 or g2 or union if there
>>> is a match - workaround for full joins not working right
>>>>> SELECT g1.field1, g1.field2, geomunion(g1.the_geom, g2.the_geom) AS
>>> newgeom
>>>>> FROM g1 INNER JOIN g2 ON (g1.the_geom && g2.the_geom AND
>>>>> UNION
>>>>> SELECT g1.field1, g1.field2, g1.the_geom AS newgeom
>>>>> WHERE g2.the_geom IS NULL
>>>>> UNION
>>>>> SELECT g1.field1, g1.field2, g2.the_geom AS newgeom
>>>>> FROM g2 LEFT JOIN g1 ON (g1.the_geom && g2.the_geom AND
>>>>> WHERE g1.the_geom IS NULL
>>>>> Hope that helps,
>>>>> Regina
>>> Andreas Laggner
>>>>> Sent: Thursday, August 23, 2007 11:32 AM
>>>>>> Oh the g1 g2 .. was just for example - I don't actually call my
>>> tables meaningless names like that.
>>>>>> You should be doing a join on something or have a where clause
>>> unless one of your tables has only one record.  Otherwise you are
>>> doing what is called a CROSS JOIN (cartesian product)  which gives you
>>> an nxm records where n is the number of records in your first table
>>> and m is the number in second table.  This is generally a big NO NO.
>>> In certain rare cases you do want to do something like that, but is
>>> usually the exception.
>>>>> I think the records in my targed table must be added (more or less) and
>>>>> not multiplied! My Aim is a table that contains the areas of all the 7
>>>>> sourcetables and the information which refuges are inside and wich not.
>>>>> Perhaps i must use the intersection!? If i do my query with a gist like
>>>>> this: where t1.the_geom && t2.the_geom; than the operation is very fast
>>>>> (about one minute) but i only have the Polygons covered by BOTH
>>>>> datasets, and i want to have as well those, which are covered by one
>>>>> dataset only!! But my operation without the where clause runs for 4
>>>>> hours now - that shows me there is something wrong  ;-)
>>>>>> Its hard for me to tell if you need a cartesian product in this
>>> case since I'm not quite sure what for example nature and biosphere
>>> represent.  I would guess that is wrong and you should first figure
>>> out which sets of say nature records you need to geomunion with
>>> biosphere and then join by that field or set of fields.
>>>>>> It would help a bit if you could provide some sample questions you
>>> expect to answer with your statistical analysis.  My guess is you may
>>> be better off with more than one table.
>>>>> Sample question: give me all areas (all polygons) from germany where
>>>>> landuse=arable land and soils=good and precipitation>600 and any (of 7)
>>>>> reserves and so on.......
>>>>> I need the values in my table to calculate the potential yield or other
>>>>> things...
>>>>> And i want to analyse such questions with a statistical software (SAS),
>>>>> so it seems to me i need one table to import in SAS (or to query from
>>>>> SAS directly to the postgresql).
>>>>> Thanks for your help, i will be back in my office in
>>> Monday.......Andreas
>>>>>> Which structure is best really boils down to what questions you
>>> hope to answer because one approach may make one question easy and
>>> fast and another question slow and cumbersome.
>>>>>> Hope that helps,
>>>>>> Regina
>>> Andreas Laggner
>>>>>> Sent: Thursday, August 23, 2007 10:04 AM
>>>>>>> Andreas,
>>>>>>> It would help to know what your table structure looks like and
>>> why do you want to put them all in a single geometry?
>>>>>> My table structures are a little bit different. I want to have
>>> them in a
>>>>>> single geometry to intersect them with other data and built a large
>>>>>> table to run statistics over it (production site analysis over
>>> germany).
>>>>>>> I'm imaging you are you doing something like
>>>>>>> SELECT g1.somefield, geomunion(geomunion(g1.the_geom,
>>> g2.the_geom), g3.the_geom)
>>>>>>> FROM g1 INNER JOIN g2 on g1.somefield = g2.somefield INNER JOIN
>>> g3 on g2.somefield = g3.somefield
>>>>>>> GROUP BY g1.somefield
>>>>>> That´s an interesting method with inner join..why go you call your
>>>>>> tables g1. g2. and so on?
>>>>>> That´s my method i am using right now (geomunion 1 to 3 from 6), seems
>>>>>> to be a pedestrian method :-(
>>>>>>     (ffh_name character varying(80), ffh_land character
>>> varying(3), ffh
>>>>>> smallint, ffh_id smallint,
>>>>>>      spa_name character varying(80), spa_land character
>>> varying(3), spa
>>>>>> smallint, spa_id smallint) with oids;
>>>>>> select
>>> addgeometrycolumn('','natura2000','the_geom','31467','MULTIPOLYGON',2);
>>>>>> alter table natura2000 drop constraint enforce_geotype_the_geom;
>>>>>>     select
>>> t1.ffh_name,t1.ffh_land,t1.ffh,t1.ffh_id,t2.spa_name,t2.spa_land,t2.spa,t2.spa_id,
>>>>>>             geomunion(t1.the_geom, t2.the_geom)
>>>>>>             from ffh_rep t1, spa_rep t2;
>>>>>> create table sg71
>>> varying(3), ffh
>>> varying(3), spa
>>>>>> smallint, spa_id smallint,
>>>>>>      bio_name character varying(70), bio smallint, bio_id
>>> smallint) with
>>>>>> oids;
>>>>>> select
>>> addgeometrycolumn('','sg71','the_geom','31467','MULTIPOLYGON',2);
>>>>>> alter table sg71 drop constraint enforce_geotype_the_geom;
>>>>>> insert into sg71
>>>>>>     select t1.ffh_name, t1.ffh_land, t1.ffh, t1.ffh_id, t1.spa_name,
>>>>>> t1.spa_land, t1.spa, t1.spa_id,
>>>>>>             t2.name,t2.bio,t2.bio_id,geomunion(t1.the_geom,
>>> t2.the_geom)
>>>>>>             from natura2000 t1, biosphere t2;
>>>>>> create table sg72
>>>>>>        (ffh_name character varying(80), ffh_land character varying(3),
>>>>>> ffh smallint, ffh_id smallint,
>>>>>>     spa_name character varying(80), spa_land character varying(3), spa
>>>>>>     bio_name character varying(70), bio smallint, bio_id smallint,
>>>>>>     np_name character varying(60), np smallint, np_id smallint)
>>> with oids;
>>>>>> select
>>> addgeometrycolumn('','sg72','the_geom','31467','MULTIPOLYGON',2);
>>>>>> alter table sg72 drop constraint enforce_geotype_the_geom;
>>>>>> insert into sg72
>>>>>>             t1.bio_name,t1.bio,t1.bio_id,t2.np_name,t2.np,t2.np_id,
>>>>>>             from sg71 t1, np t2;
>>>>>> AND SO ON......
>>>>>>> or
>>>>>>> SELECT g1.somefield, geomunion(gt.the_geom)
>>>>>>> FROM (SELECT somefield, the_geom FROM g1 UNION SELECT somefield,
>>> the_geom FROM g2 ...) gt
>>>>>>> GROUP BY gt.somefield
>>>>>>> If I have 7 different tables that have pretty much the same
>>> structure, but for logistical or other technical reasons (such as each
>>> has additional attributes distinct from one another), I need to keep
>>> them as separate tables, then I usually use inherited tables for that.
>>> That way when I need to join all datasets at once, I can simply query
>>> the parent table and it will automatically drill down to the child
>>> tables. Not sure if that helps more than it confuses your situation.
>>>>>>> Then instead of the above I can simply do
>>>>>>> SELEG myparenttable.somefield, geomunion(myparenttable.the_geom)
>>>>>>> FROM myparenttable
>>>>>>> GROUP by gh.somefield
>>>>>> ok - i have to think about your suggestions......that´s my second week
>>>>>> with postgis.
>>>>>> Can you tell me from my SQL-Statements which method will be best? So i
>>>>>> try to understand that one.....
>>>>>> Thanks for your reply!!!
>>>>>>> Hope that helps,
>>>>>>> Regina
>>> Andreas Laggner
>>>>>>> Sent: Thursday, August 23, 2007 9:11 AM
>>>>>>> To: PostGis_Mailinglist
>>>>>>> Subject: [postgis-users] Union of 7 datasets
>>>>>>> Hi users,
>>>>>>> i want to put together 7 datasets to have all the different
>>> refuges in
>>>>>>> one table (and in one geometry). Am i doing right with 6 times
>>> geomunion
>>>>>>> (that´s much to type with all the attributes) or is there a more
>>>>>>> effective way?
>>>>>>> cheers Andreas
>>> Dipl. Geoökologe Andreas Laggner
>>> Institut für Ländliche Räume (LR)
>>> Bundesforschungsanstalt für Landwirtschaft (FAL)
>>> Institute of Rural Studies
>>> Federal Agricultural Research Centre (FAL)
>>> Bundesallee 50
>>> D-38116 Braunschweig
>>> Tel.: (+49) (0)531 596 5515
>>> Fax: (+49) (0)531 596 5599
>>> E-mail: andreas.laggner at fal.de
>>> Homepage: http://www.lr.fal.de/
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> *The substance of this message, including any attachments, may be
>>> confidential, legally privileged and/or exempt from disclosure
>>> pursuant to Massachusetts law. It is intended solely for the
>>> addressee. If you received this in error, please contact the sender
>>> and delete the material from any computer. *
Bundesallee 50
