[postgis-users] Edit PostGIS data from ArcMap 9.x (ESRI ArcGIS); How about editing WFS data?
Janis Viklis janis at kartes.lv
Wed Oct 3 09:34:05 PDT 2007
I tried the "Data Interoperability Extension" that comes with ArcMap9.2,
but there is only Readonly capabilities..
but this list shows up, that there should be "Edit" options..
http://www.safe.com/esri/arcgis-data-interoperability/formats-supported.php
p.s.
on ziggis homepage is said, that "Edit" options is not done yet
Janis Viklis
IT department director
"Jana seta map publishers"
http://www.kartes.lv
Tel.: +371 6 7317540
Fax.: +371 6 7317541
Mob.: +371 2 9127952
mailto:janis at kartes.lv
skype:janisviklis
Obe, Regina wrote:
> >From what I have heard I think ArcGIS 9.3 or is it 9.4 (can't keep the
> numbers straight in my head)  will support it natively.
> There is also the ZigGIS project which is an opensource project working
> on PostGIS editing capability via ArcGIS products.  Currently I think
> they only support Read access of PostGIS data in ArcGIS.
> http://groups.google.com/group/ziggis
> You may also want to look at the Data Interoperability Extension which I
> think is a product of Safe Software http://www.safe.com FME but is
> repackaged by ESRI as a separate add-on to ArcGIS.  I haven't used it,
> so can't make any comments on it.
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Janis Viklis
> Sent: Wednesday, October 03, 2007 10:37 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Edit PostGIS data from ArcMap 9.x (ESRI
> Hi! I guess it's frequent question.. but anyway, what are the latest
> news:
> is it possible to edit PostGIS data through Esri products - ArcMap 9.x?
