Sorry, I solved it. Re: [postgis-users] no coveredby in liblwgeom.1.3.so
Steve Sweet sweet at sfos.uaf.edu
Fri Oct 5 17:37:35 PDT 2007
Sorry folks.  When I posted my question before I hadn't caught that the
subject line had changed in the posting thread I referenced.  The
original poster made a comment in the subsequent threat that clicked in
my head and it appears I've fixed the problem.
It must be Friday afternoon ...
Steve Sweet wrote:
> I should have include my configure statement:
> ./configure --with-pgsql --with-geos --with-proj=/usr/local/proj
> Steve Sweet wrote:
>> I'm trying to build postgis-1.3.1 on a Centos 5.0 system (same as
>> RedHat EL 5.0).  I built the prerequisite's immediately prior,
>> including postgresql and when it comes to the step of applying
>> lwpostgis.sql, I get exactly the same behavior referenced in this
>> posting from August 17th
>> (http://postgis.refractions.net/pipermail/postgis-users/2007-August/016749.html)
>> : the script runs fine until near the end when I get this message:
>> psql:lwpostgis.sql:4093: ERROR:  could not find function "coveredby"
>> in file "/usr/lib/pgsql/liblwgeom.so.1.3"
>> Every transaction after that step fails.
>> The linker shows it knows of the library
>> [root at dev postgis-1.3.1]# /sbin/ldconfig -v | grep geom
>>        liblwgeom.so.1 -> liblwgeom.so.1.3
>> and since most of the script runs fine it seems that the library is
>> being used.
>> This is the first build on a virgin system so there are no previous
>> library versions hanging around:
>> [root at dev pgsql]# ls -l liblwgeom*
>> lrwxrwxrwx 1 root root     16 Oct  5 12:48 liblwgeom.so ->
>> liblwgeom.so.1.3
>> lrwxrwxrwx 1 root root     16 Oct  5 12:48 liblwgeom.so.1 ->
>> liblwgeom.so.1.3
>> -rwxr-xr-x 1 root root 999008 Oct  5 12:48 liblwgeom.so.1.3
>> and there is no "coveredby" or anything close in liblwgeom.so.1.3
>> [root at dev pgsql]# nm -o liblwgeom.so.1.3 | grep -i cover
>> I'm stuck.  The answer in the previous thread was essentially "wait a
>> bit then re-grab the source and try again" but that was quite some
>> time ago.  Has any one experienced and overcome this?  Thanks.
>> Steve
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
