[postgis-users] Looks like a bug - endPoint() function crashes server
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Sun Oct 7 23:47:43 PDT 2007
On Thu, 2007-10-04 at 14:13 +0900, Anton A. Patrushev wrote:
> Hi,
> I encounter problem with endPoint() function.
> Every time I'm trying to call endPoint() function
> with PostgreSQL 8.2.5 + PostGIS 1.3.1 it crashes the backend.
> startPoint() function is working well.
> I have to use pointN(the_geom, numPoints(the_geom)) as a temporary
> workaround.
> endPoint() still works fine with PostgreSQL 8.2.4 + PostGIS 1.2.1
> Didi anybody face the same problem?
> Anton.
Hi Anton,
Yes, this is a known issue which is fixed in the latest SVN - see
http://postgis.refractions.net/pipermail/postgis-commits/2007-August/000159.html for the fix if you need it right away.
ATB,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
