[postgis-users] Missing files for pgRouting
Obe, Regina robe.dnd at cityofboston.gov
Wed Oct 10 08:14:50 PDT 2007
Andre,
Not sure why your distribution is missing it.
Anyrate - the spatial_ref_sys.sql is included in all the source
distributions - so if your install is otherwise fine, what I would
suggest you do is the following
Download the postgis-1.3.1.tar.gz from here
http://postgis.refractions.net/download/
Extract the gz and tar and copy the spatial_ref_sys.sql file from the
root of this extraction and run as you normally would.
If per chance you don't have a utility for uncompressing tar.gz and you
are on windows as it seems, I highly recommend 7Zip for Windows
http://www.7-zip.org/
It supports decompression of numerous compression formats beyond your
wildest imagination and its free.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Andre Schoonbee
Sent: Monday, October 08, 2007 3:08 PM
To: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] Missing files for pgRouting
Hi Nico
I know, but its not there, should I consider downloading an older
version of
Postgis. I am getting know error when installing postgis, in fact we
have
added data at Foss4g onto Postgis.
Regards
Andre
Nicolas
Ribot
Sent: Monday, October 08, 2007 6:21 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Missing files for pgRouting
> Hi all
> I installed Postgresql 8.2 and Postgis 1.3.1 on XP Prof. I then
installed
> pgRouting but the spatial_ref_sys.sql file is missing? Any help will
be
> appreciated!
spatial_ref_sys does not come with pgRouting.
It is a PostGIS installlation file, that you can find in the same
folder as lwpostgis.sql.
Loot at  c:\Program Files\postgresql\8.2\contrib.
Nico
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
