[postgis-users] simplify crashing postgres on larger table
Paul Ramsey pramsey at refractions.net
Mon Oct 15 14:42:46 PDT 2007
Where I used 'sizeof' I meant 'mem_size'...
On 15-Oct-07, at 2:36 PM, Paul Ramsey wrote:
> Well, you have a bug in your sights, probably, but you haven't
> isolated it...
> First, is it the UPDATE or the function?
> Does
>   SELECT sizeof(simplify(the_geom,500)) FROM thetable
> crash the backend?
> If it's the function, then, it's either the number of features and
> bad luck with a memory leak, or a single geometry that crashes the
> function.  Find out if it's the geometry by repeatedly dividing
> your data set into halves and checking each half separately.  If
> one half keeps failing, you'll eventually winnow it down to the
> offending geometry, and you can report that back here and the fix
> should be "easy".
> P.
> On 15-Oct-07, at 12:17 PM, ivan minčík wrote:
>> Halo postgis users,
>> I found that this query:
>> UPDATE table SET the_geom500=simplify(the_geom,500);
>> is crashing postgres database on 2 GB table. On smaller table
>> everything is OK.
>> I have tested this on 2 Debian Etch stable computers (postgresql
>> and postgis from repositories).
>> after some 5 minutes I always get
>> server closed the connection unexpectedly
>>        This probably means the server terminated abnormally
>>        before or while processing the request.
>> The connection to the server was lost. Attempting reset: Failed.
>> in log there is
>> 2007-10-15 21:08:47 CEST LOG:  server process (PID 5234) was
>> terminated by signal 11
>> 2007-10-15 21:08:47 CEST LOG:  terminating any other active server
>> processes
>> 2007-10-15 21:08:47 CEST LOG:  all server processes terminated;
>> reinitializing
>> 2007-10-15 21:08:47 CEST FATAL:  the database system is starting up
>> 2007-10-15 21:08:47 CEST LOG:  database system was interrupted at
>> 2007-10-15 21:08:40 CEST
>> 2007-10-15 21:08:47 CEST LOG:  checkpoint record is at 1/5BCE111C
>> 2007-10-15 21:08:47 CEST LOG:  redo record is at 1/5B546840; undo
>> record is at 0/0; shutdown FALSE
>> 2007-10-15 21:08:47 CEST LOG:  next transaction ID: 45777; next
>> OID: 131584
>> 2007-10-15 21:08:47 CEST LOG:  next MultiXactId: 1; next
>> MultiXactOffset: 0
>> 2007-10-15 21:08:47 CEST LOG:  database system was not properly
>> shut down; automatic recovery in progress
>> 2007-10-15 21:08:47 CEST LOG:  redo starts at 1/5B546840
>> 2007-10-15 21:08:50 CEST LOG:  invalid magic number 0000 in log
>> file 1, segment 98, offset 15826944
>> 2007-10-15 21:08:50 CEST LOG:  redo done at 1/62F17F90
>> 2007-10-15 21:08:55 CEST LOG:  database system is ready
>> 2007-10-15 21:08:55 CEST LOG:  transaction ID wrap limit is
>> 2147484146, limited by database "postgres"
>> Does anybody knows what is going on?
>> thanks Ivan
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
