[postgis-users] simplify crashing postgres on larger table
Paul Ramsey pramsey at refractions.net
Tue Oct 16 08:51:39 PDT 2007
Yes and no... simplify() shouldn't crash on it, it should notify on
it at worst... can you submit it?
On 16-Oct-07, at 7:18 AM, ivan minčík wrote:
> I isolated wrong geometry and I have fount that it is not valid
> polygon. So that should be the problem.
> Paul Ramsey wrote:
>> Where I used 'sizeof' I meant 'mem_size'...
>> On 15-Oct-07, at 2:36 PM, Paul Ramsey wrote:
>>> Well, you have a bug in your sights, probably, but you haven't
>>> isolated it...
>>> First, is it the UPDATE or the function?
>>> Does
>>>   SELECT sizeof(simplify(the_geom,500)) FROM thetable
>>> crash the backend?
>>> If it's the function, then, it's either the number of features
>>> and bad luck with a memory leak, or a single geometry that
>>> crashes the function.  Find out if it's the geometry by
>>> repeatedly dividing your data set into halves and checking each
>>> half separately.  If one half keeps failing, you'll eventually
>>> winnow it down to the offending geometry, and you can report that
>>> back here and the fix should be "easy".
>>> P.
>>> On 15-Oct-07, at 12:17 PM, ivan minčík wrote:
>>>> Halo postgis users,
>>>> I found that this query:
>>>> UPDATE table SET the_geom500=simplify(the_geom,500);
>>>> is crashing postgres database on 2 GB table. On smaller table
>>>> everything is OK.
>>>> I have tested this on 2 Debian Etch stable computers (postgresql
>>>> and postgis from repositories).
>>>> after some 5 minutes I always get
>>>> server closed the connection unexpectedly
>>>>        This probably means the server terminated abnormally
>>>>        before or while processing the request.
>>>> The connection to the server was lost. Attempting reset: Failed.
>>>> in log there is
>>>> 2007-10-15 21:08:47 CEST LOG:  server process (PID 5234) was
>>>> terminated by signal 11
>>>> 2007-10-15 21:08:47 CEST LOG:  terminating any other active
>>>> server processes
>>>> 2007-10-15 21:08:47 CEST LOG:  all server processes terminated;
>>>> reinitializing
>>>> 2007-10-15 21:08:47 CEST FATAL:  the database system is starting up
>>>> 2007-10-15 21:08:47 CEST LOG:  database system was interrupted
>>>> at 2007-10-15 21:08:40 CEST
>>>> 2007-10-15 21:08:47 CEST LOG:  checkpoint record is at 1/5BCE111C
>>>> 2007-10-15 21:08:47 CEST LOG:  redo record is at 1/5B546840;
>>>> undo record is at 0/0; shutdown FALSE
>>>> 2007-10-15 21:08:47 CEST LOG:  next transaction ID: 45777; next
>>>> OID: 131584
>>>> 2007-10-15 21:08:47 CEST LOG:  next MultiXactId: 1; next
>>>> MultiXactOffset: 0
>>>> 2007-10-15 21:08:47 CEST LOG:  database system was not properly
>>>> shut down; automatic recovery in progress
>>>> 2007-10-15 21:08:47 CEST LOG:  redo starts at 1/5B546840
>>>> 2007-10-15 21:08:50 CEST LOG:  invalid magic number 0000 in log
>>>> file 1, segment 98, offset 15826944
>>>> 2007-10-15 21:08:50 CEST LOG:  redo done at 1/62F17F90
>>>> 2007-10-15 21:08:55 CEST LOG:  database system is ready
>>>> 2007-10-15 21:08:55 CEST LOG:  transaction ID wrap limit is
>>>> 2147484146, limited by database "postgres"
>>>> Does anybody knows what is going on?
>>>> thanks Ivan
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
