[postgis-users] ESRI Shapes from database
Lee Keel lee.keel at uai.com
Tue Oct 16 12:41:20 PDT 2007
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Chris Hermansen
> Sent: Tuesday, October 16, 2007 2:21 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] ESRI Shapes from database
> Hmm, I think putting passwords on command lines in scripts kind of
> invalidates the whole point of having passwords...
> Talking from a "this ought to be the way" point of view, rather than
> "this is the way"... if user U is authenticated on machine X and your
> authentication mechanism is robust then U should also be authenticated
> on machine Y, so the only time a password should be needed is if U is
> trying to masquerade as someone else.
> So if user U's credentials are respected on your PostgreSQL server and
> if there is a role defined for user U in the PostgreSQL instance running
> on the server, then s/he should be able to execute psql on that server
> just by running
>    psql -h post-server database-name -f script.sql
> ¿no?
I don't have a problem with all that, I just don't know if they will buy
into it.  I am going to present this exact email to my client and see if
they will agree.
Thanks for all the help.
LK
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
