[postgis-users] loci of points
Stephen Woodbridge woodbri at swoodbridge.com
Wed Oct 17 15:36:27 PDT 2007
You might want to looks at these:
http://www.google.com/search?num=100&hl=en&newwindow=1&q=%22territory+assignment%22+algorithm&btnG=Search
-Steve
Dylan Beaudette wrote:
> SnapToGrid() ?
> Dylan
> On Wednesday 17 October 2007, Michael Welter wrote:
>> What I need to do is divide a group of geographic points into <n>
>> clusters such that the convex hulls of each cluster do not overlap.
>> Each cluster would have approximately the same number of points, and the
>> perimeter of each cluster would be minimized.
>> This is the Traveling Salesman Problem, only there are <n> salesmen.
>> The problem is how to determine the "territory" for each salesman in
>> order to minimize travel costs.
>> Thanks
>>>> Is there an algorithm to divide a group of points into <n> distinct
>>>> groups?
>>> A locus is a set of points satisfying a certain condition.
>>> So what are you conditions?
>>> There are a lot of ways an arbitrary grouping can be made from a larger
>>> set. What should determine if any given point should belong to group 1
>>> or 2 or N?
>>> It is hard to solve a problem that is under defined, unless one makes up
>>> arbitrary constraints to satisfy the problem.
>>> -Steve W.
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
