[postgis-users] ESRI Shapes from database
Steffen Macke sdteffen at gmail.com
Fri Oct 19 13:02:48 PDT 2007
> have just figured out that the COPY command requires superuser permissions.
I found the following:
> But, the copy command does allow ordinary users to use it if you are using the "FROM
> STDIN" clause.
Hope that helps.
