[postgis-users] ESRI Shapes from database
Lee Keel lee.keel at uai.com
Fri Oct 19 14:08:50 PDT 2007
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Steffen Macke
> Sent: Friday, October 19, 2007 3:03 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] ESRI Shapes from database
> Lee,
> > have just figured out that the COPY command requires superuser
> permissions.
> I found the following:
> > But, the copy command does allow ordinary users to use it if you are
> using the "FROM
> > STDIN" clause.
> Hope that helps.
> Regards,
> Steffen
> postgis-users mailing list
Steffen,
Thanks for the reply, but I am not sure how to call COPY using STDIN.  Do
you have an example?  I really don't see how to call COPY using STDIN if I
am using an npgsqlcommand object in .NET.  So I am guessing there is no
specific permission that I can grant that will allow this?  Bummer.
Thanks,
Lee Keel
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
