[postgis-users] Re: PROJ projection issues
Brian Timoney brian at thetimoneygroup.com
Fri Oct 19 14:36:27 PDT 2007
Paul:
Thanks for the quick reply.  The more recent version with dubious results was using the standard PostGIS Windows installer.
Brian
Proj has the funny build process where you have to untar the nadcon
grids into the source tree before building. If you forget that step,
your proj won't have the grids available for conversion.
P
On 19-Oct-07, at 2:03 PM, Brian Timoney wrote:
>/ Was whatever does the datum shifts between NAD27 and NAD83 not
/>/ included in more recent builds of PROJ?  Is it a 4.5 issue?/
