[postgis-users] detect poly's with duplicated vertex
Kevin Neufeld kneufeld at refractions.net
Sat Oct 20 23:17:10 PDT 2007
Try using ST_SnapToGrid(geometry, size) will remove coincident points.
To identify polygons with dups,
SELECT *
FROM mypolytable
WHERE ST_NPoints(geom) != ST_NPoints(ST_SnapToGrid(geom, <some precision>));
-- Kevin
Rob Agar wrote:
> hi all,
> Another quick question - is there a function for detecting polygons
> with one or more sequential duplicated points?  Basically, I want to
> find and replace polys like "abccd" with "abcd".
> cheers
> Rob
> postgis-users mailing list
