[postgis-users] Re: Upgrade 1.2.1 to 1.3.1 - Problems
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Mon Oct 22 04:04:09 PDT 2007
On Fri, 2007-10-19 at 00:48 -0700, Brian Hamlin wrote:
> Per-Olof
> My worst problem it seems is that I had expected the clear warnings as
> described in the README and doc.
> I just tried a freshly created DB, initialized with postgis 1.3.1 and
> got none of those terrible errors.
> So things are able to work.  It looks like I will have to 'hard
> upgrade' the three of four DBs I have so far..
> I notice that in the 1.3.2 that has appeared they say "make install may
> not work so be prepared to copy the libraries yourself" !! Perhaps they
> meant really to say
>    "ifeq ($(PORTNAME), darwin) copy the libs yourself"
> thanks for your patience
>   -Brian
Yes. It's probably because the SQL functions contain the "full" path to
the database. As you mention, the easiest solution is probably just to
restore selected tables back into a new PostGIS database. It should help
to remove the version numbers from the lwpostgis.sql as recommended by
Tom on the -devel list, but no-one has gotten around to solving this
Kind regards,
ILande - Open Source Consultancy
