[postgis-users] psql and jdbc give different result
temiz temiz at deprem.gov.tr
Mon Oct 22 11:28:24 PDT 2007
hello
String rs1ql4="select astext(wkb_geometry) from shey61_points where
yuk_nokta=(select max(yuk_nokta) from shey61_points where heycat=?)";
by preparedStatement in jdbc
                               Geometry  g3 =
wkbReader.read(WKBReader.hexToBytes(rs4.getString(1)));   ///   JTS
                               String coord3=g3.getCoordinate().toString();
                               PGgeometry obj2 =
(PGgeometry)rs4.getObject(1);                     ///    PostGIS
                               String str3=obj2.toString();
                               //String str3=g3.toString();
                               System.out.println("  coord3"+ coord3);
                               System.out.println("  str3"+ str3);
  these two give:
  coord3(469550.8043909763, 4598000.450357108, NaN)
  str3SRID=32636;POINT(469550.8043909763 4598000.450357108)
but in psql, I get :
bzk2=> select astext(wkb_geometry) from shey61_points where
yuk_nokta=(select max(yuk_nokta) from shey61_points where heycat=119);
                                      astext
 POINT(458419.167485305 4598605.03718012)
Could  you tell me  the reason  why I don't get  same coordinat values  ?
regards
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
