[postgis-users] Postresql 8.3 beta and windows problem ...
Ann Holt aholt at zylaya.com
Wed Oct 24 10:05:50 PDT 2007
Hello,
I am currently trying to evaluate upgrading to Postgresql 8.3, but
having problems even getting the complete database up and running
because I can't get PostGIS installed with the database properly.  So,
first I'm running in a Windows environment and apparently there were
some changes made in 8.3 that force the encoding for the database to
match the locale of the windows setting.  That means that I have to
set the encoding for the database to WIN1252 instead of UTF8.  This
causes the PostGIS installer to die when it tries to create the
template because it tries to create it with UTF8 encoding and postgres
won't allow that.
I then thought to try and manually do the install, and so copied the
dll from the lib in my 8.1 directory to the 8.3 directory, dumped the
template from 8.1, created the template database in 8.3 with the right
encoding and tried a restore.  The functions that referenced the dll
came back with an error : incompatible library (location of the file):
missing magic block.
Thanks for any help,
Ann
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071024/c4208683/attachment.html>
