[postgis-users] ST_Difference
Richard Heimann [C] heimann at ait.nrl.navy.mil
Wed Oct 24 16:01:28 PDT 2007
Again, thank you both Paul and Regina.
Regina, perhaps you can explain the LEFT JOIN. Nevertheless, it works with
one disclaimer. I am left with the following message, perhaps you can
demystify it?
"NOTICE:  LWGEOM_gist_joinsel called with incorrect join type
Query returned successfully with no result in 812 ms."
Paul, I also received a message from your sql though that was abit more
inauspicious. I attempted to hack your sql though unsuccessfully. The first
step is obvious; you are selecting all points that are not completely
contained within country boundaries. And although the first query provides a
list of all IDs it will not tell if the rest have the correct ids assigned
to them. So, maybe the second query performs a data integrity check? Message
below. Also, strangely, the output was a polygon feature.
"row number -1 is out of range 0..-1
Total query runtime: 703 ms.
0 rows retrieved."
Rich
  _____
From: Obe, Regina [mailto:robe.dnd at cityofboston.gov]
Sent: Wednesday, October 24, 2007 5:23 PM
To: PostGIS Users Discussion; Richard.Heimann at nrl.navy.mil
Cc: PostGIS Users Discussion
Subject: RE: [postgis-users] ST_Difference
Oops even easier
SELECT pd.*
FROM pandatestdata p LEFT JOIN world2_12nm w On  st_contains(w.the_geom,
p.the_geom)
WHERE w.id IS NULL
Here I am assuing w.id is the id of world2_12nm
  _____
From: postgis-users-bounces at postgis.refractions.net on behalf of Paul Ramsey
Sent: Wed 10/24/2007 5:01 PM
To: Richard.Heimann at nrl.navy.mil
Cc: 'PostGIS Users Discussion'
Subject: Re: [postgis-users] ST_Difference
Oh, yeah, oops, I know. It's the join logic, its finding the things
not contained for each world feature, not for the full world set.
select pd.* from pandatestdata pd,
(select p.id
from pandatestdata p, world2_12nm w
where st_contains(w.the_geom, p.the_geom)) as wd where pd.id <> wd.id;
Ugly, but probably effective: find all the things contained, then
just strip those out.
The trouble is that disjointness is not an easily spatially indexable
operation. If you're going to take this into operation with large
data volumes, a more effective data set would be ocean polygons, cut
up into smallish regular grid squares, then you can test containment
with relatively good index selectivity.
P.
On 24-Oct-07, at 1:53 PM, Richard Heimann [C] wrote:
> Thanks Paul for the response. I hadn't thought of this logic, it
> didn't work
> however. Strangely, it increased the number of features by eight
> times. Any
> thoughts?
> Vr
> Rich
> -----Original Message-----
> From: Paul Ramsey [mailto:pramsey at refractions.net]
> Sent: Wednesday, October 24, 2007 4:07 PM
> To: Richard.Heimann at nrl.navy.mil; PostGIS Users Discussion
> select p.*
> where not st_contains(w.the_geom, p.the_geom);
> On 24-Oct-07, at 11:45 AM, Richard Heimann [C] wrote:
>> Thanks for your response W. I should have posted the sql query
>> earlier.
>> Anyway...its below.
>> My goal is to drop all features (points) that fall within my
>> polygon. In
>> this case, I have ship track data and want to filter it with world
>> country
>> buffers.
>> World2_12nm - my world country 12nm buffered polygon
>> Pandatestdata - track data (point)
>> Panda_diff2 - new table
>> CREATE TABLE panda_diff2 AS
>> SELECT AsText(Difference(world2_12nm.the_geom,
>> pandatestdata.the_geom)) FROM
>> world2_12nm, pandatestdata
>> Also attached are the astext versions of my data as well as a csv
>> of the
>> output from the above sql. Please debunk the mystery...
>> Thanks again
>> Rich
>> From: Webb Sprague [mailto:webb.sprague at gmail.com]
>> Sent: Wednesday, October 24, 2007 12:00 PM
>> You might get more useful help if you post an "astext()" version of
>> your data, the query, the result, and  a *desired* result.
>> I know the difference functions can be tricky and are sometiimes
>> defined in ways you might not expect.
>> Thx
>> W
>> On 10/24/07, Richard Heimann [C] <heimann at ait.nrl.navy.mil> wrote:
>>> All,
>>> I would appreciate help in constructing an SQL statement that
>>> performs a
>>> difference function on two datasets. My intersect function works but
>> cannot
>>> work out the kinks with st_difference. Thanks for your help.Im
>>> new to
>>> Postgis.
>>> Rich
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> <panda_diff2.csv>
  _____
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure pursuant to
Massachusetts law. It is intended solely for the addressee. If you received
this in error, please contact the sender and delete the material from any
computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20071024/c004fddc/attachment.html>
