[postgis-users] where to register to submit bug?
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Mon Oct 29 10:28:59 PDT 2007
On Mon, 2007-10-29 at 18:20 +0100, ivan minčík wrote:
> thanks, I just wanted to submit bug described in this thread
> http://postgis.refractions.net/pipermail/postgis-users/2007-October/017365.html
> this is one of the objects which was the reason
>  MULTIPOLYGON(((-333399.63 -1270249.25,-333416.78 -1270247.43,-333415.54
> -1270231.88,-333411.49 -1270209.38)),((-333408.1 -1270235.32,-333408.8
> -1270244.32,-333401.1
> -1270245.02,-333400.5 -1270236.12,-333408.1 -1270235.32)),((-333397.27
> -1270210.4)),((-333397.58 -1270214.37)))
> ivan
Strange. Works for me here:
postgis=# select version();
                                              version
 PostgreSQL 8.3beta2 on i686-pc-linux-gnu, compiled by GCC gcc (GCC)
4.0.3 (Ubuntu 4.0.3-1ubuntu5)
(1 row)
postgis=# select postgis_full_version();
 POSTGIS="1.3.2" GEOS="3.0.0rc4-CAPI-1.3.3" PROJ="Rel. 4.5.0, 22 Oct
2006" USE_STATS
(1 row)
postgis=# select ST_simplify('MULTIPOLYGON(((-333399.63
-1270249.25,-333416.78 -1270247.43,-333415.54 -1270231.88,-333411.49
-1270209.38)),((-333408.1 -1270235.32,-333408.8 -1270244.32,-333401.1
-1270210.4)),((-333397.58 -1270214.37)))', 500);ERROR:  geometry
contains non-closed rings
postgis=#
Does the above work for you? If not, what does SELECT version() and
SELECT postgis_full_version() return?
ATB,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
