[postgis-users] where to register to submit bug?
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Tue Oct 30 16:24:12 PDT 2007
On Mon, 2007-10-29 at 23:25 +0100, ivan minčík wrote:
> I made pg_dump from the table. You can download it here:
>           http://disk.jabbim.cz/hrach@jabber.cz/bug_db.tar.gz
> You have to:
>     1. change my database user (called ivo) to Your user
>     2. createdb somedb
>     3. psql -U youruser -f bug_db.sql somedb
> try
>     select simplify(the_geom,100) from bug_table where icutjcpa =
> '8601232244003';
> is it ok that way?
> thanks
>     Ivan
Hi Ivan,
Yes, that's fine - not sure exactly when I'll get a chance to look at
it, but I'll see what I can do. Can you also confirm the version of
PostgreSQL used to produce the dump? (SELECT version())
Many thanks,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
