[postgis-users] Intersection errors out with null directed edge
Paul Ramsey pramsey at refractions.net
Thu Sep 13 08:32:44 PDT 2007
Plus, GEOS3 is still binary compatible with GEOS2.2 at the C API
level, so you can actually upgrade just be doing a ./configure ;
make ; make install of GEOS3, and then restarting postgresql.
P
On 13-Sep-07, at 8:28 AM, Martin Davis wrote:
> Chris,
> As Andreas pointed out, recent (Dec 06) work on GEOS has largely
> fixed this problem (which is likely due to a robustness issue -
> although it could also be due to invalid data!  You should check
> your data to make sure it is fully valid, using isValid() )
> Try upgrading and see if the problem goes away.  There's not really
> any other great solution to this problem.
> Martin
> Chris Hermansen wrote:
>> Hi folks;
>> I had this problem today:
>> AssertionFailedException: EdgeRing::computePoints: found null
>> Directed
>> Edge
>> I see in the archives that there are others who have suffered
>> this, back
>> in 2006 and then in 2005, but there don't seem to be any offerings of
>> techniques to either repair the code or the data - and based on the
>> error above, I'm not sure which is ultimately at fault.
>> Does anyone have some more up-to-date thought on this?
>> I'm running postgis-1.3.1 on Ubuntu with the packaged postgresql-8.2
>> installed.
>> Thanks in advance!
> Martin Davis
> Senior Technical Architect
> Refractions Research, Inc.
> (250) 383-3022
> postgis-users mailing list
