[postgis-users] AsKML() how to create kml from postgis data
Kevin Neufeld kneufeld at refractions.net
Fri Sep 14 16:03:34 PDT 2007
Absolutely.
See attached, a simple plpgsql function that adds header info around the
current askml function.
I do this in psql:
-- Set output to unaligned
\a
-- Show only tuples
\t
-- Dump query to a file
\o my_kml_file.kml
-- Run your query
SELECT askml('my_line', 'description', 'SRID=3005;LINESTRING( 1190000
390000, 1200000 390000, 1200000 380000, 1190000 380000, 1190000 390000
)'::geometry);
-- Flush output your file and close the output stream
\o
Loading this file in Google Earth will draw a box around Victoria, BC.
I often collect() geometries from a table and pass those into this function:
SELECT askml('my_title', 'description', collect(the_geom)) FROM my_line
table WHERE ....
Cheers,
Kevin
Kevin Neufeld
Software Developer
Refractions Research Inc.
300-1207 Douglas St.
Victoria, B.C., V8W 2E7
Phone: (250) 383-3022
Email: kneufeld at refractions.net
Maciej Skorczewski wrote:
> hi all!
> How should i use AsKML() function to create KML files (w try show
> postgis data in google maps nad google earth)
> It is posible?
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070914/7a02d424/attachment.ksh>
