[postgis-users] How to get the centroid of an bounding box using st_extent
Charlie Savage cfis at savagexi.com
Tue Sep 18 20:56:50 PDT 2007
It turns out that st_extent is hundreds of times faster than Envelope.
But I run into a problem when using it:
select st_extent('POINT(10 10)')
"BOX(10 10,10 10)"
But if you do this:
select asText(centroid(st_extent('POINT(10 10)')))
"GEOMETRYCOLLECTION EMPTY"
Which is the same issue I mentioned a couple weeks ago where
Envelope('POINT(10 10)') doesn't return a point like it should.
So I'd like to use st_extent, but a need a way to get a valid point that
represents the center of the bounds instead of an empty collection.  How?
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070918/65743d3b/attachment.bin>
