[postgis-users] Union of 7 datasets
Obe, Regina robe.dnd at cityofboston.gov
Wed Sep 26 06:20:52 PDT 2007
I didn't read your last message before I sent this one.  Anyrate below I made a typo should be
st_intersects(ffh, spas) and st_is_empty(st_difference(ffh, spa)) = false
Kevin's I suspect is more accurate since with mine, you will probably get extra records if it returns at all the right result and if it does return somewhat accurate you would probably have to do an additional collect - wrap the whole set of unions into something like
SELECT ffhs, spas, st_collect(DISTINCT newset.geomcollection) as newgeom
FROM
(big old set of unions goes here) as newset
GROUP BY newset.ffhs, newset.spas (excluding the geom column)
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Obe, Regina
Sent: Wednesday, September 26, 2007 9:11 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] Union of 7 datasets
Sorry Andreas,
I would have expected if anything that the parts that intersect would have attributes from spa and ffh
Some parts that don't intersect but are part of overlapping/intersecting polygons would have attributes from both (which is wrong)
And the others that are not part of intersecting polygons would have only ffh or spa attributes.
Perhaps you can send us some sample datasets results.
So the only problem join I see would be the first one (our intersection one).  That one I would think we would want to break out further into (psuedo syntax below)
ffhs , spas
 , st_intersection(ffh, spa)
where st_intersects(ffh,spas)
union all
ffh, null(spas), st_difference(ffh, spa)
where st_intersects(ffh, spas)  && st_is_empty(st_difference(ffh, spa)) = false
union all
null(ffhs), spas, st_difference(spa, ffh)
where st_intersects(ffh, spas)  && st_is_empty(st_difference(spa, ffh)) = false
Note if you are using an older version of postgis you may need to replace
st_intersects with ffh && spa AND intersects(ffh, spas)
and get rid of the other st_
Also I must add that my geometry pinnings are a bit weak so I probably have all my definitions about overlaps and intersects mixed up.  Here is my basic understanding of geometric concepts so perhaps someone can correct me if I am wrong in any part which most likely I am
1) A intersects B if some part of A and B are shared.
2) A overlaps B only if the intersection of A and B is not A or B or the empty set - (meaning A can't be fully contained in B and B can't be fully contained in A but parts of A or B are shared).
Of course this throws out my concept of why A && B returns true when A and B have the same bounding box but st_overlaps(A,B) is false when A and B are the same polygon. - I always thought A&&B means overlaps boundary boxes which seems closer match the definition of intersects.  So I am thoroughly confused.
3) difference(A,B) will return that part of A that is not within B.
Thanks,
Regina
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Andreas Laggner
Sent: Tuesday, September 25, 2007 9:41 AM
Subject: Re: [postgis-users] Union of 7 datasets
Hi Regina,
your last hint with collect brings me closer to my goal!!
I ran this query now - my geometries are exactly what i wanted to have!
There only problem left is: If polygons intersect, they always have the
attributes from spa only, never from ffh. Parts, that contain spa AND
ffh only have the spa-attributes, and this parts from a overlapping
polygon, that are only ffh, have no attributes at all.
Can you find the error in the query?
cheers      Andreas
drop table natura2000;
create table natura2000
    (ffh_name character varying(80),ffh_land character varying(3),ffh
smallint,ffh_id smallint,
     spa_name character varying(80),spa_land character varying(3),spa
smallint,spa_id smallint)
    with oids;
select
addgeometrycolumn('','natura2000','the_geom','31467','MULTIPOLYGON',2);
alter table natura2000 drop constraint enforce_geotype_the_geom;
insert into natura2000
(ffh_name,ffh_land,ffh,ffh_id,spa_name,spa_land,spa,spa_id,the_geom)
 select ffh_rep.ffh_name,ffh_rep.ffh_land,ffh_rep.ffh,ffh_rep.ffh_id,
    spa_rep.spa_name,spa_rep.spa_land,spa_rep.spa,spa_rep.spa_id,
    collect(ffh_rep.the_geom, spa_rep.the_geom) as geomcollection
    from ffh_rep inner join spa_rep
    on (ffh_rep.the_geom && spa_rep.the_geom and
intersects(ffh_rep.the_geom, spa_rep.the_geom))
    union all
 -- the second select gives you ffh_reps that have no spa_reps - your 15
      null as spa_name, null as spa_land, null as spa, null as spa_id,
      ffh_rep.the_geom as the_geom
   from ffh_rep left join spa_rep
    where spa_rep.the_geom is null
    union all
 -- and the 3rd gives you spa_reps that have no ffh_reps. - your 40
    select  null as ffh_name, null as ffh_land, null as ffh, null as ffh_id,
        spa_rep.the_geom AS the_geom
    from spa_rep left join ffh_rep
    where ffh_rep.the_geom is null;
Obe, Regina schrieb:
> Not sure I quite understand the question.  You mean to store these 3 geometries separately so you can color code as needed or overlay as needed?
> In that case you would have 3 separate geometry fields
>   intersection(ffh_rep.the_geom, spa_rep.the_geom) As geomintersection, ffh_rep.the_geom As ffh_geom, spa_rep.the_geom As spa_geom
> For the ones where there is only udo or kai then I guess you can fill in the same geometry for all geometry fields.
> and then overlay them on your map as separate layers as needed
> or if you mean you just want it to look like figure 1 but not necessarily color coded, then you would do
> Hope that helps,
> Regina
> Sent: Thursday, August 30, 2007 7:24 AM
> Moin Regina,
> the query you suggested is a very big step forward, but it does not
> exactly what i want to have  ;-)  ...  it seems to me i will need an
> intersection in one part and not a geomunion!! But i want to ask you:
> what it does correctly: I now have a union of all geometries from both
> source datasets.
> If i have a single udo (ffh_rep) that intersects no kai (spa_rep) the
> row only has the attributes from udo. Same thing i have with single kai.
> That is all correct.
> BUT: If udo and kai intersects i will not have new polygons!! For
> example: blue is udo (or ffh_rep) and yellow is kai (or spa_rep). I want
> to have three polygons than with blue only the attributes from udo,
> yellow only the attributes from kai AND the intersection, polygon number
> 3, the green one (blue with yellow points) with the attributes from udo
> and kai (figure1). And now i have one Polygon having the attributes from
> udo and kai (figure2).
> figure1:
> figure1
> figure2:
> figure2
> My query:
>     with oids;
> select
> addgeometrycolumn('','natura2000','newgeom','31467','MULTIPOLYGON',2);
> alter table natura2000 drop constraint enforce_geotype_newgeom;
> (ffh_name,ffh_land,ffh,ffh_id,spa_name,spa_land,spa,spa_id,newgeom)
>     geomunion(ffh_rep.the_geom, spa_rep.the_geom) as newgeom
>     union all
>       ffh_rep.the_geom as newgeom
>     union all
>         spa_rep.the_geom AS newgeom
> Cheers    Andreas
>> Andreas,
>> You would use the SQL UNION predicate like shown below (actually
>> slight correction - it is speedier to use UNION ALL especially when
>> you know there will not be dupiclates since it saves the processing of
>> sorting to get a distinct UNION does an implicit distinct)  - so I
>> have corrected below.
>> -  - I happened to insert comments in between which may have confused
>> you, but you should be able to run the whole thing as one statement or
>> if you prefer because of speed issues run each insert separately.
>> So  would be
>> INSERT INTO sometable(field1, field2,field3,field4, newgeom)
>>  SELECT udo.field1, udo.field2, kai.field3, kai.field4,
>> geomunion(udo.the_geom, kai.the_geom) AS newgeom
>>   FROM udo INNER JOIN kai ON (udo.the_geom && kai.the_geom AND
>> intersects(udo.the_geom, kai.the_geom))
>>   UNION ALL
>>  -- the second select gives you udos that have no kais - your 15
>>   SELECT udo.field1, udo.field2, NULL As field3, NULL As field4,
>> udo.the_geom AS newgeom
>>   FROM udo LEFT JOIN kai ON (udo.the_geom && kai.the_geom AND
>>   WHERE kai.the_geom IS NULL
>>  UNION ALL
>>  -- and the 3rd gives you kais that have no udos. - your 40
>>   SELECT NULL As field1, null As field2, kai.field3, kai.field4,
>> kai.the_geom AS newgeom
>>   FROM kai LEFT JOIN udo ON (udo.the_geom && kai.the_geom AND
>>   WHERE udo.the_geom IS NULL;
>> ----If FULL JOIN were to work (which in theory it should, but doesn't
>> seem to with Postgis functions  (HINT HINT: would be nice if
>> that worked and can be easily fixed (but sadly I think the issue is
>> deeper than Postgis and Geos) - you could write the above much simpler as)
>> COALESCE(geomunion(udo.the_geom, kai.the_geom), udo.the_geom,
>>   FROM udo FULL JOIN kai ON (udo.the_geom && kai.the_geom AND
>> Now if you have a lot of these and the tables are very similar in
>> nature and named in a predictable way then the way I usually handle it
>> is to write a pgsql function that dynamically generates the SQL
>> statement to execute either via a FOR loop and then executes the built
>> SQL or set of SQL statements or you could do a similar thing in some
>> scripted language like perl or php.
>> I take it SQL and pgsql and all that is fairly new to you so it might
>> be worthwhile (even though its a lot of typing) to do it the long cut
>> and paste way if nothing more than an exercise to get a feel of how
>> this all works and visualize the patterns at play.
>> I don't get the sense that I comprehend your full problem.
>> Unfortunately I don't have any experience with ArcGIS/ArcView ways of
>> doing things, so I'm not quite sure if there is an equivalent way in
>> PostGIS/PostgreSQL  world of doing the same kind of thing and what
>> exactly that thing is you are doing in ArcGIS.
>> Union has 3 meanings in PostGIS/PostgreSQL (actually stuff your
>> favorite spatial/DB here - all non-trivial spatial relational dbs
>> behave more or less the same)
>> 1) unioning of record sets (standard ANSI SQL UNION/UNION ALL) - which
>> is simply a way of stringing together a bunch of selects into a
>> single result set as shown above
>> 2)  unioning of 2 geometry fields like shown above with geomunion
>> 3) Aggregate  geomunion - aggregate variant of the above geomunion
>> function that groups and unions a whole setof geometries together but
>> requires you are grouping by some field or set of fields).
>> I must also mention there is collect (non-aggregate and aggregate
>> function) which often times is just as effective as the geomunion and
>> in general much faster processor wise.
>> Hope that helps,
>> Regina
>> Andreas Laggner
>> Sent: Tuesday, August 28, 2007 9:13 AM
>>>  Sounds like you would have to go with a full join type thing with
>> workaround I described below (last example).  So If I understand you
>> correctly then something like this -
>>> --the first select gives you those records in both tables your 25 udokai
>>>  UNION
>>>  UNION
>>>  SELECT nul As field1, null As field2, kai.field3, kai.field4,
>>> Unioned together you should get
>>> 25 + 15 + 40 = ? 80
>>> Hope that helps,
>>> Regina
>> UFF - that seems to be a complex question, a comprehensive operation and
>> a lot to type too!!! Thanks a million - i would have spent many time to
>> find out this query by myself! Ok..... how can i perform your "UNION": I
>> would just insert my selects one after another in one new table - will
>> that work well?
>> I want to aggregate around 20 datasets this way!? Do you know a method
>> to operate with more datasets (for example 7) in a effektiv manner and
>> not to do this three selects 6 times?
>> AND: Am i totally wrong with my aims? It seems to me that is an exotic
>> think to do with PostGis, but our projects/problems require to aggregate
>> datasets in almost all cases (around 90%) and that is exactly what one
>> of the basic functions "Union" in ArcView already carried out ten years
>> ago. So i would exspect there is a function to perform this operation
>> easier!? .....i just wonder.....
>> cheers      Andreas
>> Andreas Laggner
>>> Sent: Tuesday, August 28, 2007 7:28 AM
>>>> BASIC TRICK:  If you want to get all records with no matching
>> including those that match - put what you would normally put in your
>> WHERE clause in the JOIN clause and use a LEFT JOIN.
>>> ok - it seems to me i need some coaching......Yes, I want to get all
>>> records with no matching including those that match, but i also want to
>>> dissect the polygons that matches. I will try to explain again just to
>>> be sure you understood my aims: I have 20 polygons in udo and 50 in kai.
>>> 10 from kai are intersecting 5 from udo to 25 new polygons i call udokai
>>> (because they have attributes from udo AND kai). My result should have:
>>> 15 polygons with attributes only from udo, 40 polygons with attributes
>>> only from kai AND 25 with attributes from udo and kai! In most cases i
>>> want to do such a operation because i want to aggregate (spatial
>>> correct) different datasets!
>>> Which example from you fits best for this aim? I did not find any
>>> information on how left join works on the postgis or postgresql
>> reference...
>>>> Unfortunately as I have come across before if you need an either or
>> (if in table 1 or table 2 - ideally you would use a FULL JOIN but for
>> some reason Postgres chokes when you use postgis functions in the FULL
>> JOIN clause for the cases I have tried).  In that case you need a
>> workaround using a set of UNIONS.
>>>> Simplest case - get all records in g1 one or union of g1 and g2
>> that intersect
>>>> NOTE: COALESCE is an ANSI SQL function that will return the first
>> non-null - when you do a geomunion of a geometry and null you get null
>> which is why we need COALESCE
>>>> SELECT g1.field1, g1.field2, COALESCE(geomunion(g1.the_geom,
>> g2.the_geom), g1.the_geom) AS newgeom
>>>> FROM g1 LEFT JOIN g2 ON (g1.the_geom && g2.the_geom AND
>> intersects(g1.the_geom, g2.the_geom))
>>>> Either of case - get all geometries in g1 or g2 or union if there
>> is a match - workaround for full joins not working right
>>>> SELECT g1.field1, g1.field2, geomunion(g1.the_geom, g2.the_geom) AS
>> newgeom
>>>> FROM g1 INNER JOIN g2 ON (g1.the_geom && g2.the_geom AND
>>>> UNION
>>>> SELECT g1.field1, g1.field2, g1.the_geom AS newgeom
>>>> WHERE g2.the_geom IS NULL
>>>> UNION
>>>> SELECT g1.field1, g1.field2, g2.the_geom AS newgeom
>>>> FROM g2 LEFT JOIN g1 ON (g1.the_geom && g2.the_geom AND
>>>> WHERE g1.the_geom IS NULL
>>>> Hope that helps,
>>>> Regina
>> Andreas Laggner
>>>> Sent: Thursday, August 23, 2007 11:32 AM
>>>>> Oh the g1 g2 .. was just for example - I don't actually call my
>> tables meaningless names like that.
>>>>> You should be doing a join on something or have a where clause
>> unless one of your tables has only one record.  Otherwise you are
>> doing what is called a CROSS JOIN (cartesian product)  which gives you
>> an nxm records where n is the number of records in your first table
>> and m is the number in second table.  This is generally a big NO NO.
>> In certain rare cases you do want to do something like that, but is
>> usually the exception.
>>>> I think the records in my targed table must be added (more or less) and
>>>> not multiplied! My Aim is a table that contains the areas of all the 7
>>>> sourcetables and the information which refuges are inside and wich not.
>>>> Perhaps i must use the intersection!? If i do my query with a gist like
>>>> this: where t1.the_geom && t2.the_geom; than the operation is very fast
>>>> (about one minute) but i only have the Polygons covered by BOTH
>>>> datasets, and i want to have as well those, which are covered by one
>>>> dataset only!! But my operation without the where clause runs for 4
>>>> hours now - that shows me there is something wrong  ;-)
>>>>> Its hard for me to tell if you need a cartesian product in this
>> case since I'm not quite sure what for example nature and biosphere
>> represent.  I would guess that is wrong and you should first figure
>> out which sets of say nature records you need to geomunion with
>> biosphere and then join by that field or set of fields.
>>>>> It would help a bit if you could provide some sample questions you
>> expect to answer with your statistical analysis.  My guess is you may
>> be better off with more than one table.
>>>> Sample question: give me all areas (all polygons) from germany where
>>>> landuse=arable land and soils=good and precipitation>600 and any (of 7)
>>>> reserves and so on.......
>>>> I need the values in my table to calculate the potential yield or other
>>>> things...
>>>> And i want to analyse such questions with a statistical software (SAS),
>>>> so it seems to me i need one table to import in SAS (or to query from
>>>> SAS directly to the postgresql).
>>>> Thanks for your help, i will be back in my office in
>> Monday.......Andreas
>>>>> Which structure is best really boils down to what questions you
>> hope to answer because one approach may make one question easy and
>> fast and another question slow and cumbersome.
>>>>> Hope that helps,
>>>>> Regina
>> Andreas Laggner
>>>>> Sent: Thursday, August 23, 2007 10:04 AM
>>>>>> Andreas,
>>>>>> It would help to know what your table structure looks like and
>> why do you want to put them all in a single geometry?
>>>>> My table structures are a little bit different. I want to have
>> them in a
>>>>> single geometry to intersect them with other data and built a large
>>>>> table to run statistics over it (production site analysis over
>> germany).
>>>>>> I'm imaging you are you doing something like
>>>>>> SELECT g1.somefield, geomunion(geomunion(g1.the_geom,
>> g2.the_geom), g3.the_geom)
>>>>>> FROM g1 INNER JOIN g2 on g1.somefield = g2.somefield INNER JOIN
>> g3 on g2.somefield = g3.somefield
>>>>>> GROUP BY g1.somefield
>>>>> That´s an interesting method with inner join..why go you call your
>>>>> tables g1. g2. and so on?
>>>>> That´s my method i am using right now (geomunion 1 to 3 from 6), seems
>>>>> to be a pedestrian method :-(
>>>>>     (ffh_name character varying(80), ffh_land character
>> varying(3), ffh
>>>>> smallint, ffh_id smallint,
>>>>>      spa_name character varying(80), spa_land character
>> varying(3), spa
>>>>> smallint, spa_id smallint) with oids;
>>>>> select
>>>>>     select
>> t1.ffh_name,t1.ffh_land,t1.ffh,t1.ffh_id,t2.spa_name,t2.spa_land,t2.spa,t2.spa_id,
>>>>>             geomunion(t1.the_geom, t2.the_geom)
>>>>>             from ffh_rep t1, spa_rep t2;
>>>>> create table sg71
>> varying(3), ffh
>> varying(3), spa
>>>>> smallint, spa_id smallint,
>>>>>      bio_name character varying(70), bio smallint, bio_id
>> smallint) with
>>>>> oids;
>>>>> select
>> addgeometrycolumn('','sg71','the_geom','31467','MULTIPOLYGON',2);
>>>>> alter table sg71 drop constraint enforce_geotype_the_geom;
>>>>> insert into sg71
>>>>>     select t1.ffh_name, t1.ffh_land, t1.ffh, t1.ffh_id, t1.spa_name,
>>>>> t1.spa_land, t1.spa, t1.spa_id,
>>>>>             t2.name,t2.bio,t2.bio_id,geomunion(t1.the_geom,
>> t2.the_geom)
>>>>>             from natura2000 t1, biosphere t2;
>>>>> create table sg72
>>>>>        (ffh_name character varying(80), ffh_land character varying(3),
>>>>> ffh smallint, ffh_id smallint,
>>>>>     spa_name character varying(80), spa_land character varying(3), spa
>>>>>     bio_name character varying(70), bio smallint, bio_id smallint,
>>>>>     np_name character varying(60), np smallint, np_id smallint)
>> with oids;
>>>>> select
>> addgeometrycolumn('','sg72','the_geom','31467','MULTIPOLYGON',2);
>>>>> alter table sg72 drop constraint enforce_geotype_the_geom;
>>>>> insert into sg72
>>>>>             t1.bio_name,t1.bio,t1.bio_id,t2.np_name,t2.np,t2.np_id,
>>>>>             from sg71 t1, np t2;
>>>>> AND SO ON......
>>>>>> or
>>>>>> SELECT g1.somefield, geomunion(gt.the_geom)
>>>>>> FROM (SELECT somefield, the_geom FROM g1 UNION SELECT somefield,
>> the_geom FROM g2 ...) gt
>>>>>> GROUP BY gt.somefield
>>>>>> If I have 7 different tables that have pretty much the same
>> structure, but for logistical or other technical reasons (such as each
>> has additional attributes distinct from one another), I need to keep
>> them as separate tables, then I usually use inherited tables for that.
>> That way when I need to join all datasets at once, I can simply query
>> the parent table and it will automatically drill down to the child
>> tables. Not sure if that helps more than it confuses your situation.
>>>>>> Then instead of the above I can simply do
>>>>>> SELEG myparenttable.somefield, geomunion(myparenttable.the_geom)
>>>>>> FROM myparenttable
>>>>>> GROUP by gh.somefield
>>>>> ok - i have to think about your suggestions......that´s my second week
>>>>> with postgis.
>>>>> Can you tell me from my SQL-Statements which method will be best? So i
>>>>> try to understand that one.....
>>>>> Thanks for your reply!!!
>>>>>> Hope that helps,
>>>>>> Regina
>> Andreas Laggner
>>>>>> Sent: Thursday, August 23, 2007 9:11 AM
>>>>>> To: PostGis_Mailinglist
>>>>>> Subject: [postgis-users] Union of 7 datasets
>>>>>> Hi users,
>>>>>> i want to put together 7 datasets to have all the different
>> refuges in
>>>>>> one table (and in one geometry). Am i doing right with 6 times
>> geomunion
>>>>>> (that´s much to type with all the attributes) or is there a more
>>>>>> effective way?
>>>>>> cheers Andreas
>> Dipl. Geoökologe Andreas Laggner
>> Institut für Ländliche Räume (LR)
>> Bundesforschungsanstalt für Landwirtschaft (FAL)
>> Institute of Rural Studies
>> Federal Agricultural Research Centre (FAL)
>> Bundesallee 50
>> D-38116 Braunschweig
>> Tel.: (+49) (0)531 596 5515
>> Fax: (+49) (0)531 596 5599
>> E-mail: andreas.laggner at fal.de
>> Homepage: http://www.lr.fal.de/
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> *The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended solely for the
>> addressee. If you received this in error, please contact the sender
>> and delete the material from any computer. *
Bundesallee 50
