[postgis-users] Three point ARC to MULTILINESTRING
JohanNL johan12365 at hotmail.com
Sun Apr 20 08:07:32 PDT 2008
Thanks Paul! It works perfect.
Johan.
Paul Ramsey-3 wrote:
> Use the CIRCULARSTRING type, and the ST_CurveToLine(geometry) function
> to convert it to a linestring.
> CREATE TABLE test ( GEOM geometry );
> INSERT INTO test VALUES ('CIRCULARSTRING(0 0, 1 1, 2 0)');
> SELECT ST_AsText(ST_CurveToLine(geom)) FROM test;
> P
> On Fri, Apr 18, 2008 at 7:53 AM, JohanNL <johan12365 at hotmail.com> wrote:
>>  Hi All,
>>  I have a question. I need to store an Arc into a postgis database. As
>> far as
>>  I know, Postgis doens't support arcs. Is there another way to convert a
>>  Three Point Arc to a MultiLineString?
>>  Best regards,
>>  Johan.
>>  View this message in context:
>> http://www.nabble.com/Three-point-ARC-to-MULTILINESTRING-tp16763471p16763471.html
>>  Sent from the PostGIS - User mailing list archive at Nabble.com.
>>  _______________________________________________
>>  postgis-users mailing list
>>  postgis-users at postgis.refractions.net
>>  http://postgis.refractions.net/mailman/listinfo/postgis-users
View this message in context: http://www.nabble.com/Three-point-ARC-to-MULTILINESTRING-tp16763471p16793239.html
