[postgis-users] GeoJson export function
Paul Ramsey pramsey at cleverelephant.ca
Thu Apr 24 07:58:14 PDT 2008
There's a regression issue then, because I needed to *add* those lines
to get it to pass...
On the regression side, could you please change your regression suite
a bit to match the style of the OGC suite? See how each tests also
echos out a test number? It makes it far easier to traverse from the
failure diff to the actual failed test.
Thanks,
Paul
On Wed, Apr 23, 2008 at 11:59 PM, Courtin Olivier
<olivier.courtin at camptocamp.com> wrote:
>  Only one report, on regress/run_test geojson,
>  2 additionals lines 've been inserted from the previous
>  patch.
>  If i call run_test geojson i've got now an error ;
>  a patch to fix this (remove the 2 lines)
