[postgis-users] Merge all polygons from a dataset
Obe, Regina robe.dnd at cityofboston.gov
Fri Aug 1 04:15:33 PDT 2008
Erik,
How were you using ST_Union and what exactly do you mean by no result.
no result as it looks blank?  If you are using something like PgAdmin
III - it will look blank because it exceeds the buffer supported by
PgAdmin III.
SELECT the_geom is null
FROM (somequery or table) as foo
LIMIT 1
will tell you if its actually returning no geometry
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
danny
Sent: Friday, August 01, 2008 6:12 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Merge all polygons from a dataset
Hello everybody,
I've converted a shapefile of Europe to PostGIS. I would like to merge
all the countries together so that I only have one polygon left, the
whole contour of Europe. I have tried ST_Union that gives me no result.
I've tried several other functions to no avail. Does anybody know how I
should proceed?
Many thanks,
Erik
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080801/734a8a0e/attachment.html>
