[postgis-users] ST_Intersects
danny whatevar89 at gmail.com
Tue Aug 5 04:14:30 PDT 2008
Guido, it's a bufferzone around the contour of europe.
On Tue, Aug 5, 2008 at 1:02 PM, Guido Lemoine <guido.lemoine at jrc.it> wrote:
> Erik,
> I don't know why european_waters would be a single complex polygon?
> Do you mean it is a MULTIPOLYGON in Postgis? If so, it is easy to
> break it apart in single polygons. If it includes rivers, I can't imagine
> why it
> is a polygon in the first place. I would expect a LINESTRING (or
> MULTILINESTRING in your case).
> This explains, of course, why performance is not much improved. The &&
> operation does not really affect that.
> GL
> danny wrote:
>> Thanks Guido!
>> The sample you gave performed slightly better: 304 seconds. I'll still
>> have to wait a few months to let it run on all my data though. Yes, sitecode
>> has a "normal" index, not a spatial one. Both the_geom's have spatial ones.
>> The european_waters polygon is one single complex polygon, scale 1/100000.
>> What's annoying is that when I do an intersect in Arc View it's almost
>> instantaneous. Of course I don't get exaclty what I wan't but with some
>> tweaking I can maybe get closer. That would be a great disappointment
>> though. I was really looking forward to using ST_Within intensively!
>> Thanks Jean David, no performance gain though by using it in the WHERE
>> clause, where I intended to use it in the first place. I put it in the
>> Select for testing purposes.
>> explain select  sitecode from sites a,  europe_waters b
>> where st_intersects(a.the_geom,b.the_geom) and a.sitecode = 'xxxx';
>> "Nested Loop  (cost=0.00..461.71 rows=1 width=10)"
>> "  Join Filter: _st_intersects(a.the_geom, b.the_geom)"
>> "  ->  Seq Scan on sites a  (cost=0.00..453.43 rows=1 width=35764)"
>> "        Filter: ((sitecode)::text = 'xxxx'::text)"
>> "  ->  Index Scan using idx_europe_waters on europe_waters b
>>  (cost=0.00..8.27 rows=1 width=32)"
>> "        Index Cond: (a.the_geom && b.the_geom)"
>> "        Filter: (a.the_geom && b.the_geom)"
>> On Tue, Aug 5, 2008 at 10:53 AM, Guido Lemoine <guido.lemoine at jrc.it<mailto:
>> guido.lemoine at jrc.it>> wrote:
>>    Erik
>>    Try this, and see if it is any faster:
>>    select  st_intersects(a.the_geom,b.the_geom) from sites a,
>>     europe_waters b where a.the_geom && b.the_geom and
>>    I guess you mean that sitecode is indexed (not spatially indexed),
>>    because it seems to be a varchar.
>>    Both a and b should have a spatial index on the_geom, but I reckon
>>    that is already the case. Also,
>>    b (europe_layer) should not be a single polygon, but rather a set
>>    of polygons.
>>    This is lesson 1 in the PostGIS tutorial, more or less. In return
>>    for my 2 minutes effort, you are
>>    obliged to report the new performance report, so that future users
>>    will benefit.
>>    After all, I just saved you half a year...
>>    GL
>>    danny wrote:
>>        Hello,
>>        I'm wondering if it's normal to have a 420 second response
>>        time for the following query.
>>        A spatial index has been set on the spatial field (the_geom)
>>        and other important fields (like sitecode). I've generously
>>        tweaked the memory options for postgresql.
>>        With such a response time I would have to let my query run for
>>        half a year before getting the answer I'm interested in! :)
>>        Anybody know how I can boost up the process or is it doomed to
>>        always be so slow? The europe_layer is indeed a complex
>>        polygon....
>>         europe_waters b where a.sitecode = 'xxxx';
>>        "Nested Loop  (cost=0.00..496.18 rows=1310 width=35786)"
>>        width=35754)"
>>        "  ->  Seq Scan on europe_waters b  (cost=0.00..23.10
>>        rows=1310 width=32)"
>>        My true objective would be to join thses two tables through an
>>        st_intersects but for the time it is unconceivable.
>>        Many thanks,
>>        Erik
>>        _______________________________________________
>>        postgis-users mailing list
>>        postgis-users at postgis.refractions.net
>>        <mailto:postgis-users at postgis.refractions.net>
>>        http://postgis.refractions.net/mailman/listinfo/postgis-users
>>    Guido Lemoine
>>    Joint Research Centre, European Commission
>>    Institute for the Protection and Security of the Citizen (IPSC)
>>    Support to External Security
>>    Via E. Fermi, 2749 TP 267 Ispra 21027 (VA), Italy
>>    Tel. +39 0332 786239 (direct line) Fax. +39 0332 785154
>>    WWW: http://ses.jrc.it
>>    Disclaimer:
>>    Views expressed are those of the individual and do not represent
>>    the views of the European Commission
> Guido Lemoine
> Disclaimer:
> Views expressed are those of the individual and do not represent the views
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080805/533ac8ce/attachment.html>
