[postgis-users] Update Error
Obe, Regina robe.dnd at cityofboston.gov
Tue Aug 5 19:59:56 PDT 2008
ST_GeomFromText takes the form ST_GeomFromText('POINT(' || raw.x || ' ' || raw.y || ')', 102249)
Anyrate for point geometries its more efficient to use ST_MakePoint  so something like
UPDATE recent
SET xypoint = ST_SetSRID(ST_MakePoint(raw.x, raw.y),102249)
from raw
where recent.casenum=raw.casenum;
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net on behalf of Donald Ijams
Sent: Tue 8/5/2008 6:00 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Update Error
When I attempt to update a geometry column from a field in another table
with:
UPDATE recent
SET xypoint = ST_GeomFromText((raw.x, raw.y),102249)
from raw
I get:
*SQL error:*
ERROR:  function st_geomfromtext(record, integer) does not exist
LINE 3: xypoint = ST_GeomFromText((raw.x, raw.y),102249)
HINT:  No function matches the given name and argument types. You might need to add explicit type casts.
Probably something simple, but I'm not seeing it.
Don
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080805/61d5ef9c/attachment.html>
