[postgis-users] How to add spatial functions to a custom schema
gimbrogno magnitudo9 at email.it
Mon Aug 11 04:50:44 PDT 2008
Hi, thanks for your answer but it is not my problem...
I have to create spatial functions under a schema called 'info', and If I
use psql -d myDb -f lwpostgis.sql, the spatial functions are created under
the schema 'public'!
How Can I make spatial function under schema 'info' ?
Thanks a lot in advance...
Mark Lidstone wrote:
> Hi Gimborgno,
> I think all you need to do is add the schema name as the first argument
> to the AddGeometryColumn procedure.  E.g. replace:
> SELECT AddGeometryColumn('table', 'field', 4326, 'POINT', 2);
> with:
> SELECT AddGeometryColumn('new_schema', 'table', 'field', 4326, 'POINT',
> 2);
> Thanks,
> Mark Lidstone
> Tel: +44 (0)23 80232222; Fax: +44 (0)23 80232891
> BMT Cordah Ltd
> Grove House
> 7 Ocean Way
> Ocean Village
> Southampton
> SO14 3TJ
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> gimbrogno
> Sent: 11 August 2008 12:34
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] How to add spatial functions to a custom schema
> Hi all,
> I have a problem with spatial functions to a new custom schema.
> I made a db, and following the PostGIS documentation I have created the
> spatial extensions on it, but under the 'public' schema... How can I
> create the spatial extensions on a custom schema?
> PS: English is not my native language, so excuse me for errors...
> http://www.nabble.com/How-to-add-spatial-functions-to-a-custom-schema-tp
> 18923897p18923897.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> BMT Cordah Ltd.
> A member of the BMT group of companies
> Registered Office: Investment House, 6 Union Row, Aberdeen AB10 1DQ
> Registered in Scotland No. 163413
> http://www.bmtcordah.com/
> http://www.bmt.org/
> The contents of this e-mail and any attachments are intended only for the
> use of the e-mail addressee(s) shown. If you are not that person, or one
> of those persons, you are not allowed to take any action based upon it or
> to copy it, forward, distribute or disclose the contents of it and you
> should please delete it from your system. BMT Cordah Limited does not
> accept liability for any errors or omissions in the context of this e-mail
> or its attachments, which arise as a result of Internet transmission, nor
> accept liability for statements which are those of the author and not
> clearly made on behalf of BMT Cordah Limited.
View this message in context: http://www.nabble.com/How-to-add-spatial-functions-to-a-custom-schema-tp18923897p18924157.html
