[postgis-users] Update
Bob Pawley rjpawley at shaw.ca
Wed Aug 13 11:02:59 PDT 2008
Is there a way of updating an existing column using ST_Translate.
When I try it I get error messages.
I could do it with an insert -  create table, insert, update then drop
table - but it would be nice if it was more straightforward.
Following is my function.
Bob
 Update p_id.processes
 set arrow_the_geom = Select st_transform (graphics.utilities_dgm.the_geom,
 st_x (st_centroid(p_id.p_id.the_geom)) -
 st_x (st_centroid (graphics.utilities_dgm.the_geom)),
 st_y (st_centroid(p_id.p_id.the_geom))-
 st_y (st_centroid (graphics.utilities_dgm.the_geom)))
 From graphics.utilities_dgm, p_id.p_id
 where graphics.utilities_dgm.utilities_description = 'Arrow_Flow_Direction'
 and graphics.utilities_dgm.orientation = p_id.processes.orient;
