[postgis-users] PostGIS 1.3.3 on Windows XP Unstable
Bresnahan, Mike Mike.Bresnahan at bestbuy.com
Thu Aug 14 10:58:58 PDT 2008
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA256
> Union will have the desired effect, but it isn't the most efficient
way
> of dealing with the problem.  The most efficient way is to iterate
over
> all the polygons in the MultiPolygon, and drop any which are contained
> in another one in the set.
I'm having a hard time figuring out how to do this, because I cannot
figure out a way to store a set in a local variable. I need to do
something like this:
    myset := (select ScrubPolygon(geom)
             from (select (ST_Dump(input)).geom) as x);
And then something like this:
output := (select ST_Collect(f1.the_geom) from myset f1, myset f2
           where not ST_Within(f1.the_geom, f2.the_geom));
But I cannot figure out how to store the set in a variable. AFAIK, it is
not possible to declare a variable of type "setoff geometry". I also
tried using a temporary table, but there doesn't seem to be a way to
create one in the scope of a function call.
Another approach would be to collect all the polygons into a single
multipolygon and then scrub the nested shells from that, but I have not
found a way to efficiently append a polygon to a multipolygon.
-----BEGIN PGP SIGNATURE-----
Version: PGP Universal 2.8.3
Charset: us-ascii
wsBVAwUBSKRxUB6WPRoYuvd0AQhSlQgAsB37OJl3ZA+3+kqJGbwNkQR5Cfqmd/Sf
0n74UED6yKkCmzDy04yDIrIdHInSy3Lm2j9nIBl8nTaeK4ZOSJZcYpvInj0CEDAE
OXgU2ij0LUrkRPHo8gmwt5xab8XbHhx/v4Na648nbz917R31vXQwmgK5Oi0+vQxf
tMpm7ZQcuSaegkbOsyGL+l0WwY9nGlC9pnFt8y20A04AsD+bIa5l2GBo869qbnJm
CcPneGAyb1EwdWqY/ATrjobY97P86jtEQ9d9VsB2+1f34tKQfD0weEHU/Cii1GF1
JH4gNGFVgZgz/yug9nMDwFlEZW1KMpH00/ilHbDzqsYXH/Hojp4ijA==
=Grft
-----END PGP SIGNATURE-----
