[postgis-users] Convert multipolygons to separate polygons
Dane Springmeyer blake at hailmail.net
Tue Aug 19 16:00:02 PDT 2008
Hi Simon,
Yes,
This is one approach:
SELECT ST_PointOnSurface(ST_GeometryN(geometry, generate_series(1,
ST_NumGeometries(geometry)))) AS single_geometry_turned_into_point
FROM your_table;
Cheers,
Dane
On Aug 19, 2008, at 3:46 PM, Simon O'Malley wrote:
> Hi All
> Is there a way to split multipolygons into separate polygon features?
> Or is there a way to step through all the polygons in a multipolygon
> and use pointonsurface to create a point for each polygon in the
> multipolygon.
> Thanks in advance.
> Simon
> postgis-users mailing list
