[postgis-users] schema name for a temp table?
David William Bitner david.bitner at gmail.com
Tue Aug 26 06:54:33 PDT 2008
Nope, you don't have to use addgeometrycolumn at all.  You just need to
create a table with a column declared as geometry.
Create table foo (my_geom_column geometry, my_id serial, my_attribute
varchar);
On Tue, Aug 26, 2008 at 8:20 AM, Burgholzer,Robert <
rwburgholzer at deq.virginia.gov> wrote:
> Kevin,
> Thanks for the response.  By spatially enabled, I mean, has a geometry
> column, and I wish to use that column for comparison operators, such as
> st_within().  Furthermore, since I am adding the column to a table of
> data, then setting the geom column to table lat/lon values, I needed to
> use addgeometrycolumn (at least I think that I need to do that).
> Anyhow, your query gives me just the information that I need.  Thanks!
> r.b.
> Robert W. Burgholzer
> Surface Water Modeler
> Office of Water Supply and Planning
> Virginia Department of Environmental Quality
> 804-698-4405
> Open Source Modeling Tools:
> http://sourceforge.net/projects/npsource/
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Kevin Neufeld
> Sent: Monday, August 25, 2008 5:51 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] schema name for a temp table?
> SELECT nspname FROM pg_namespace WHERE oid = pg_my_temp_schema();
> But what exactly do you mean by "spatially enabled"?  Any table with a
> geometry column is "spatially enabled".  It may not be registered with
> the geometry_columns metadata table or have spatial constraints on it,
> but it is capable of holding spatial data.
> ie.
> CREATE TEMP TABLE test (id integer, the_geom geometry);
> \d
>      Table "pg_temp_11.test"
>   Column  |   Type   | Modifiers
>  id       | integer  |
>  the_geom | geometry |
> Cheers,
> Kevin
> Burgholzer,Robert wrote:
> > I have a temporary table that I would like to spatially enable.  Thus,
> I
> > need to know the proper schema name, assuming that the schema name
> would
> > change if there were multiple temp tables with the same name (a
> > possibility if several users are hitting the app simultaneously).
> > Has anyone had any experience with this?
> > Thanks!
> > r/b/
> > 804-698-4405
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080826/925097a6/attachment.html>
