[postgis-users] problem with OIDS
David Fawcett david.fawcett at gmail.com
Tue Aug 26 12:36:12 PDT 2008
I am guessing that you are using ms4w 2.2.8, which would put your
MapServer version at 5.x.
I haven't used MapLab, does it build and write map files to the
filesystem?  If so, can you share the text of your map file,
specifically, the layer definition for consejospopulares?  My
assumption is that you need to modify the query in your data
statement.
David.
On Tue, Aug 26, 2008 at 2:29 PM, fsalas <fsalas at geocuba.cu> wrote:
> Hi, Regina,
> I have postgreesql 8.3 with postgis_1_3_3_pg83.exe and mapserver 2.2.8
> This is the message of the Maplab when i try to browse the map File.
> Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named
> 'consejospopulares'. in C:\ms4w\apps\maplab-2.2\htdocs\mapedit\preview.php
> on line 469
> Warning: [MapServer Error]: prepare_database(): Error declaring cursor:
> ERROR: column "oid" does not exist LINE 1:
> ...sbinary(force_collection(force_2d(geoloc)),'NDR'),OID::text ... ^ With
> query string: DECLARE mycursor BINARY CURSOR FOR SELECT
> asbinary(force_collection(force_2d(geoloc)),'NDR'),OID::text from
> consejospopulares WHERE geoloc && setSRID('BOX3D(214616.053511706
> 284600,230683.946488294 295300)'::BOX3D,
> find_srid('','consejospopulares','geoloc') ) in
> C:\ms4w\apps\maplab-2.2\htdocs\mapedit\preview.php on line 469
> can you Tell me , How I can resolve this situation?
> Best Regards,Salas
> ----- Original Message -----
> From: Obe, Regina
> To: fsalas ; PostGIS Users Discussion
> Sent: Tuesday, August 26, 2008 9:29 AM
> Subject: RE: [postgis-users] problem with OIDS
> OIDS=true is obsolete because it has limitations on size and PostgreSQL in
> general has been trying to get people to stop using it for general user
> tables.  Mapserver works fine for me without it and uses the gid field.
> What sort of problem are you having? Could be a completely different issue
> or you are running a really old version of mapserver.
> Hope that helps,
> Regina
> ________________________________
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of fsalas
> Sent: Tuesday, August 26, 2008 9:04 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] problem with OIDS
> Hi,
> in this moment I have problems with mapserver and postgis.
> This is the sentence create with shp2pgsql.exe why set the
> WITH (OIDS=FALSE)?;
> How I can change this to OIDS=TRUE
> CREATE TABLE areasalud
>   gid serial NOT NULL,
>   codasalud bigint,
>   "version" bigint,
>   descasalud character varying(40),
>   geoloc geometry,
>   CONSTRAINT areasalud_pkey PRIMARY KEY (gid),
>   CONSTRAINT enforce_dims_geoloc CHECK (ndims(geoloc) = 2),
>   CONSTRAINT enforce_geotype_geoloc CHECK (geometrytype(geoloc) =
> 'MULTIPOLYGON'::text OR geoloc IS NULL),
>   CONSTRAINT enforce_srid_geoloc CHECK (srid(geoloc) = 2085)
> WITH (OIDS=TRUE);
> ALTER TABLE areasalud OWNER TO postgres;
> bets regards
> Salas
> postgis-users mailing list
