[postgis-users] AddGeometryColumn error
javier.estevez.ext at juntadeandalucia.es javier.estevez.ext at juntadeandalucia.es
Wed Aug 27 10:23:06 PDT 2008
I tried one thing:
I create a new table in the database including PostGIS functions. This query
is CORRECT now:
SELECT addgeometrycolumn('public','tablenew','the_geom',23030,'POINT',2)
The problem right now is... How can I import the PostGIS functions into my
DATABASE??????
> The function is there and executing, however it is complaining that it
> cannot find the table name in the public schema.
> What was your original table create statement for the "estac_aemet"
> table? "CREATE TABLE public.estac_aemet (field type, etc... "
> Did you use special accent characters in its creation?
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On
>> Behalf Of javier.estevez.ext at juntadeandalucia.es
>> Sent: Wednesday, August 27, 2008 8:13 AM
>> To: PostGIS Users Discussion
>> Cc: PostGIS Users Discussion
>> Subject: Re: [postgis-users] AddGeometryColumn error
>> Correctly, I have 3 databases: postgres (This my DB),
>> demo_postgis and template_postgis
>> In my DB there is no FUNCTIONS
>> In template_postgis there are all the POSTGIS functions.
>> Can I import from 'my DB' all PostGIS functions that are in other DB
>> (template_postgis)
>> Thanks.
>> > Hi,
>> > maybe your instalation of postgis functions and etc are not in
>> > postgres db. If you are using windwos search for others databases,
>> > maybe a postgis or postgis_template. At that databases you
>> will find
>> > the the functions.
>> > If you are using linux then you will have to add that functions to
>> > some database, see the docs for a how-to.
>> > A good policy is to create a new database using a template with the
>> > postgis stuff. Leave the postgres db for maintenance.
>> > Best regards,
>> > 2008/8/27 <javier.estevez.ext at juntadeandalucia.es>
>> >> No, is correct like 'estac_aemet'
>> >> How do I know if my POSTGIS functions are installed ok?
>> >> In my DB called 'postgres' I have no Functions.
>> >> >> Yes, the tabla estac_aemet exists. The schema is public
>> >> > Did you create the table using double quotes to name it ?
>> >> > "ESTAC_AEMET"
>> >> maybe
>> >> > If so, then you have to respect the case in the table name when
>> >> > naming
>> >> it:
>> >> > SELECT addgeometrycolumn('public','ESTAC_AEMET', 'the_geom',
>> >> 23030,'POINT',2)
>> >> > You can check the table name by launching psql and typing \d to
>> >> > list all tables.
>> >> > Nicolas
>> >> > _______________________________________________
>> >> > postgis-users mailing list postgis-users at postgis.refractions.net
>> >> > http://postgis.refractions.net/mailman/listinfo/postgis-users
>> > Luigi Castro Cardeles
